9 members (Montegue, gmcn, hillclimber, MJF, AlyMatt, Mark+4, TBM, Graham, G4FUJ, AndyGoff),
298
82
Topics49,858
Posts837,463
Posts: 318 |
I presume I have the old system fitted on my S4,since I have the small keyfob? Or did the factory install the immobiliser type from S4 and up?
Rudolf.
Morgan Aero8 S4 «Tango» Fisker Ocean Harley Davidson Livewire BMW R100/7 , R100R Moto Guzzi 254
Posts: 979 |
My unit failed a few years ago on the S3 and the factory replaced it from stock units for the AeroSS. Still working well.
Posts: 469 |
I'm not sure what unit was fitted to what models, we are talking Morgan! I'm just waiting for the dealer to get back after contacting the factory again, if no luck then I'll try the Hawk unit. Thanks again everyone
2017 Mercedes Benz SLC 200 AMG. 2019 Mercedes Benz GLA 200 AMG Now Ex-Mogger!
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Just out of interest, where is this central locking module located?
Martin (Deano)
Posts: 1,242 |
Just out of interest, where is this central locking module located? Deano to find the remote central door locking module you remove the glove box assemble and its up under the bulk head. As I remember the unit is connected to BMW switch gear. Good luck if you plan to do it your self its a bit of a mission.
Graham
Posts: 469 |
Hi Deano, mine fell out from under the glove box! so easy to sort out, I put it back with some adhesive Velcro to the side of the glove box behind the leather trim.
Thank guys, mines currently working ok but if I get problems in the future, then I will know what to do.
Martin (Deano)
Posts: 318 |
Hi
I believe mine was replaced with the SS system also - really annoying the boot doesn't open with the remote - or should it be ?
Gajet
2013 Plus 8 Aero S5 Build week 11
Hi
Gajet Originally the boot would have openned with the remote
Martin (Deano)
Posts: 3,838 Likes: 9
le Asbo du Bling Talk Morgan Addict
Posts: 3,838 Likes: 9 |
Hi
Gajet Originally the boot would have opened with the remote I had mine pack up on the Series 2 and traced the fault to the mechanism which from memory was from a Fiesta. Changed the unit and worked a treat afterwards.
Slowly going green
