8 members (High Hamster, BillHart, DJC, mph, MartinB60, Morganmike, DMC1904, Graham, G4FUJ),
278
43
Topics48,364
Posts813,337
Members9,215
Posts: 1,338 |
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsf2db0bdd.jpg.html]  [/url]][/url]
Posts: 1,338 |
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps19fa9961.jpg.html]  [/url]][/url]
Posts: 1,562 |
Posts: 2,361 |
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
today i clean my air filter and i see that all the air filter is moving up and dawn about 1 cm and a connector is in contact with the right cylinder. i make a support
warning i found the problem it was put without two fixation on the engine
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Good to hear it's solved.
Richard 1976 4/4 4 Seater
Posts: 1,562 |
Hi Atlanta Did you make those brackets you show in your last picture or were they in withering the adaptor kit?
Posts: 1,338 |
-I installed my filter with the adaptor only. -I didn't use the factory back plate that was on the factory filter. -The adaptor kit doesn't come with brackets
I do brackets The air filter must be hold on the cylinders as it is with the original one from morgan. Mine was moving when i touch it, all the pipe was translating about 1cm Now it doesn ´t move at all
