3 members (G Walker, sewin, Julian BB), 303 guests, and 39 robots.
+8Rich 94
John V6 50
Posts837,996
rockabilly john
#180449 06/02/14 05:36 PM
LarryS Offline OP
One of the improvements Morgan made to the suspension is a welded in place cross-bar. Does anyone know if the bolted in version can be retro-welded and, if all the other upgrades are fitted, does it really make much difference? Does anyone have pictures of both versions?
I was shown an article in Morgan World magazine which had pictures of the 2014 changes including my first view of the NVH ? Bracket for the bevel box. I don't recall seeing the cross bracket as it was just a quick look.
I presume it is the latest edition.
Can any one scan and post pix?
Don't have a photo of the original style bolted brace but here's one of the new style welded in A-frame arrangement;
2014 and late 2013 front frame stiffening.
I have seen pictures of this x-brace, it has 3 parts:
2 diagonals, from where the bolted in brace brackets are back to a central position on a cross bar which is just underneath the front grill.
Then a brace between the diagonals above the steering rack.
I hope my description conjures up the correct picture in your mind.
I have a pic from 2011- does this show the early chassis detail you were after? Gerry.
Gerry
JVS Offline
My unit #917 has a bolted in crossbar right behind the engine cylinders and over the steering rack. Don't have any cross bars that connect to the main cross frame under front bonnet. Stronger than the early frames buy less bracing than the 2014 units
Sorry no picture today
JV Sclafani
Boca Raton, FL
'13 M3W Metallic Orange Pearl
128CI Steered by Empire - Riding on Ohlins
This one docent even have the bolted in x-brace as there are no lugs to bolt it to.
Has anyone noticed a weakness on the former chassis type while driving? or could it be an issue we need to check on after x000 miles?
There have been some chassis breakages, not too many, but keep an eye on that area. It may be possible for a good fabricator to make and weld in a brace similar to the Morgan one?
Here's a couple of photos of the bolted in cross bar on a late 2013 chassis.
Chassis #1001 for those interested.
Left Hand Side
Right Hand Side
