2 members (Alistair, stumog), 351 guests, and 33 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,336
Christoph
#180512 07/02/14 12:51 AM
1955er Offline OP
Hi Guys,
My '74 4/4 has the crossflow engine/twin choke Weber carb with a black foam mesh filter.
How often should it be cleaned? I do not live in a particularly dusty environment and I rarely take it out bush innocent
After cleaning this, is there a particular oil that I should use or will any engine oil do?
How saturated should it be?......obviously not dripping but conversely do I squeeze out all excess?
As always, many thanks for any advice.
Cheers,
Neil.
1975 4/4 4 seater, cream over blue; Q3 Quattro; Bicycle; Walking poles.
1955er #180545 07/02/14 08:39 AM
Posting Desperado
Posting Desperado
Twin Webers on mine DCNF down draughts . I remove them at the start of the season and soak them in a tray of white spirit ( NOT TURPS ) . Let them evaporate dry . K&N do an air filter oil ( its pink ) 8fl onz give them a coating ( instrutions on the bottle ) , you will get a bit over spray on the bonnet after your job, but it wipes off and no damage from it . Do the same when you put it away at the end of summer . OH I forgot its OZ no winter over there . thumbs
Just had my b/fast 10.30am now I can think I need a mug of coffee to help.
Details from the plastic bottle
If your K&N High Flow Performance Air Filter is white ( not red ) inside the pleats, it must be oiled before installation and after each cleaning . It's easy heres how.
Gently squeeze a small stream of K&N Oil along the leanght of each pleat on your filter(CAUTION )use restraint...and its easy to get to much on the filter )
After oiling, let flter sit for 20 minutes so the oil can dissipate throughout the gauze, resulting in a uniform light red color
Do not over-oil . Any white patches remaining after 20 minutes may be finished off with a drop or two of oil.
Your K&N Filter will provide efficent , high flow service for extended periods and will not require cleaning until completely covered with a thick layer of dirt. ( I dont get mine like that .
Sort out the bones in this lot and it should help you owe me a beer and a burger mate and not that Fosters crap.
Off for more coffee thumbs
1955er #180569 07/02/14 10:50 AM
Interesting Jack - often wondered how it was done.
1955er #180577 07/02/14 11:36 AM
K&N do a Air Cleaner Recharge kit. It has a cleaner and a oil in it plus good instructions. Cost is $20 from a good motor accessory shop ( auto 1 or Repco). You get more than a couple of uses out of the kit
thumbs
Graeme: 2011 +4
Digimap #180608 07/02/14 01:52 PM
Can't see if it is correct, but I was told K&N oil is just overpriced TQF (automatic transmission oil). When I ran a K&N, I certainly used it, and just washed it clean with a small amount of petrol.
TQF is an oil, and is the right colour, but after that you're on your own.
Jack The Lad #180685 07/02/14 10:09 PM
1955er Offline OP
Thanks for that info JTL. thumbs
Will shout you next time I see you!
Actually I would love to visit my old stomping ground......must put it on the itinerary for next UK trip.
Neil.
Digimap #180686 07/02/14 10:13 PM
1955er Offline OP
thumbs
Thanks Digimap and Martyn for the suggestions.
The combined knowledge of this site is awesome notworthy
Cheers,
Neil.
