1 members (ChrisConvertible),
212
32
Topics49,841
Posts837,323
Posts: 14,009 |
When I come down tomorrow please can you hide that Lotus......I do not want any temptation! Easter would never forgive me!
Posts: 28,892 Likes: 350
Posts: 28,892 Likes: 350 |
I still think we should have a driving session at Lotus, to taste the Elise and Evora...
Posts: 1,711 Likes: 1
Posts: 1,711 Likes: 1 |
 Yes, Yes, Yes Finally shoulder felt good enough to drive. I dont care if it was on the freeway in early peak hour, i did it. A little tender by the time I arrived at work, after all it was 26Km and that is at least 260 gear changes  . Never mind it will get better in time for me to drive home. I will probably cop an earful from  but it will have been worth it
Graeme: 2011 +4
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Brilliant news Graeme - no stopping you now
One Hopes, I can now drive it to get the motor changed over.
Graeme: 2011 +4
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
 Yes, Yes, Yes Finally shoulder felt good enough to drive. I dont care if it was on the freeway in early peak hour, i did it. A little tender by the time I arrived at work, after all it was 26Km and that is at least 260 gear changes  . Never mind it will get better in time for me to drive home. I will probably cop an earful from  but it will have been worth it Great to hear!
Richard 1976 4/4 4 Seater
Posts: 1,418 |
Ross on Wye was lovely yesterday in the sunshine but D-hell the amount of water ! However, have wimped out today as am going to the Theatre at Malvern  tonight and the forecast is unrelenting  Using  's camper van instead : advantage = ability to make a brew if held up anywhere  Jeremy
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
On a cold and blistery day here in Florida, but sufficient for Morgan jaunts, I finally found the rear end clank that plagued my runs in the Plus 8 of late. The tubular shock tower is both bolted and welded (belt and suspenders?) to the angle iron cross member that sits at the top of the shock hoop. The passenger side weld was broken and the bolt loose. I tightened the bolt to within an inch of its life. I suspect the weld should be re done. Any similar experiences or thoughts? Cheers, Mark
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 14,009 |
Wet and windy drive down the M5 to Williams today. The trip tested my new windscreen pillar trims out....no more popping out of the side screens! Just need to get the single drip from the header rail sorted!
My wallet stayed firmly in my pocket even if my taxi drivers didn't (you know who you are!) and in spite of seeing and hearing the rather impressive audio set up Williams have just fitted to a customers Roadster. Nice to see a fellow TMers car there also being fitted with something similar.
Posts: 3,643 |
......it was only a dash clock, nothing too expensive, this time.
The audio system sounded great.
Nice friendly dealership.
