2 members (TBM, Alistair), 335 guests, and 41 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,347
Christoph
Page 3 of 4 1 2 3 4
Interesting info here.
As an update - I have now cleaned, scrubbed and cleaned again the calipers. They are now painted (but not baked, this can happen on the car over time).
I've also taken the opportunity to paint the rear brake drums whilst the wheels were all off for new tires today. They are now refitted with new bolts.
The new pistons should arrive next week so can be fitted with new seals etc. and can then be refitted.
I have now also moved my number plate to the left hand side of the car (looks neat, but not symmetrical) so that the air scoop can work to its maximum. Whilst I was under the car I fitted a rubber air dam. When I get the brakes back on I hope this will lower the running temperatures in the WA summer!
A fun filled couple of days.
Richard, that look extremely smart!
Thanks!
Just as an update this week whilst I was away the new pistons and seals arrived. They fitted quite easily.
With new bleed screws fitted the are ready to refit when the correct brake hoses arrive after my leave. Nearly there.
Looks great Richard thumbs
I think I will add 'painting brakes' to my to-do list... wink
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Thanks - painting was not on my to do list but since I had the time whist waiting for parts I did it. Pleased that I did.
Looks very smart Richard! thumbs
In 2012 I came across this company when prepping to paint my rear drums (car drums that is...)
http://biggred.co.uk/
Didn't use them but from research found lots have good things to say.
On return from my break in the southwest of WA the new brake pipes from BHM had arrived complete with crush copper washers.
I fitted the passenger side and installed the "Green Stuff" pads (without the 3M backing, but with copper slip due to clearances) and started on the drivers side. All was going well until I tightened up the brake pipe to the caliper when it sheared at the "shoulder" of the pipe just as the washer started to crush. frown
Thankfully the thread inside the caliper just twisted out with an "easy out" between my fingers.
BHM service excellent as normal and a new pipe is on its way! Seeming a manufacturing issue??
Just now need the new pipe, to bleed the brakes, a bit of luck and the overhaul is complete!
What is noticeable is that the passenger wheel which always slightly binded is now much better and rotates freely with only light "drag" from the brake pads at one point. Must have got the brake discs on OK!
Page 3 of 4 1 2 3 4
