0 members (),
396
100
Topics49,872
Posts837,705
Posts: 9 |
First post so be gentle.......
Do the Goodrich braided hoses dispense with the hard line fitted to the calpiers? I have just purchased a set (SMN 0300-3c) for my 1992 4/4 and the front hoses are longer than the original rubber hoses and have an end fitting that looks like it fits directly to the caliper. I have queried with Goodrich and they say that the hoses they supply fit directly to the caliper and do not connect to the pipe that is fitted to the caliper as original (Goodrich describe this as the hard line).
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Err, I'd need to get underneath my car, but I believe so. Welcome to TM, BTW
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Not sure about the answer to your question (but I am sure someone will know) but welcome to Talk Morgan
Bud 4/4 "Stanley"
Posts: 2,361 |
Remove the old rubber brake hose that comes off your brake calipers. Fit the new metal braided brake line in its place. Re bleed brakes. Job done
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 218 |
@nigels brother welcome ! And please if you have to ask these questions, don't touch anything and go to your local garage and watch, or ask Nigel.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
I was recently supplied the "new" rubber brake hose instead of one to fit a 70's car.
The newer one had the same tapered fitting on both end to fit a flare nut. The "older" fitting had this on one end only and on the other a flat/shoulder fitting straight to the caliper.
Richard 1976 4/4 4 Seater
Posts: 16 |
Hi,when removing the old pipe and bracket don't forget to safely wire up the caliper bolts,not sure where you would wire them as they attach to the old brackets.
