1 members (Ian B), 319 guests, and 104 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
Moggo
Page 3 of 9 1 2 3 4 5 6 7 8 9
P Dron #184050 27/02/14 04:27 AM
I need to order one new rear tyre.
Symetrical seems to be better
À narrow tyre ?
It is now a 175/65/15 H 84
P Dron #184061 27/02/14 08:58 AM
It depends on whether you want it to last a long time, but not grip so well, or want it to be sticky and wear out in a couple of thousand kms?
P Dron #184092 27/02/14 01:00 PM
The Yokohama last 6000 miles
I see today à Michelin energy saver .
What do you think about it ?
P Dron Offline OP
My view of Michelin tyres is that they are generally very competent in all respects, but not necessarily the best (often out-performed in comparative tests by Vredestein, for example). On top of that, if you want a more expensive tyre than a Michelin, you usually have to make an effort to find it.
I suspect that this Michelin is too good for the rear of the M3W. For the same reason, I have decided I do not want a Vredestein either - it would probably be even better than the Michelin and definitely less expensive.
What I want on the Morgan's rear wheel is a hard-wearing tyre of good quality but moderate performance. I do not want too much grip.
P Dron #184098 27/02/14 01:56 PM
Symetrical or not
First price are symetrical
And suraly dont have so much grip
P Dron Offline OP
Symetrical or not
Could be interesting. A Michelin X might be good - that certainly did not have much grip!
P Dron #184117 27/02/14 05:51 PM
Michelin X or XZX would certainly out last the car but so would a steel band and give about the same grip.
Try looking at a Hankook, I have used them for years with good results.
P Dron Offline OP
I was wondering about Hankook. Seems worth a try. Thanks.
P Dron #254222 19/02/15 11:31 PM
WW11 MOG
WW11 MOG
I've done 5k miles and the tread on my Yokohama Bluearth is down to around 3mm. I've got a track day next week so guess it will need renewing soon after.
I've emailed Mark Reeves for advice about which tyre is best. Mark said he has tried a few different makes but none could beat the Yokohama.
I am going to follow Marks advice and order another Yokohama Bluearth, but I'm unsure if a regular car tyre fitting bay is the right place to get the job done. Even if I remove the rear wheel myself, won't it still have the rear pulley attached? If so, will it fit on a tyre balancing machine like a regular car wheel?
Any advice would be appreciated. Thanks
Austin
P Dron #254230 20/02/15 06:50 AM
Rear pulley is bolt on so can be easily removed.
