5 members (TalkMorgan, Burgundymog, DCH, Davetherave, Montegue), 250 guests, and 96 robots.
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,437
Page 2 of 4 1 2 3 4
Spirit Offline OP
Originally Posted By Q8morgan
Item 231151841582 on ebay
But actually it looks like 1 tire
Or
Take it to a autoshop & try your luck
Thanks Q8, yes I saw that listing. My tires are brand new so I really do not want to buy a new one yet. I am hoping Mr.Whitewall will be the solution.
Past The City Limits
I think the hardest thing may be that the sidewalls look hard to keep clean. I saw a few SD cars at the factory getting upgrades or warranty work and the orange looked more like beige, the colour of an old rubber band.
I had whitewalls on my 1980 MGBGT. At that time it had become the fashion, and dealers had the whitewalling machines - of which there must be some still around. I wouldn't have gone for this option, but it had already been done. A thin layer of white material was laid in an abraded ultra shallow groove in the sidewall.
What happened was that the oils in the rubber yellowed the white very quickly. In the end I used a whitewall crayon to stop them looking tatty, but the flexing of the sidewalls meant that the surface was always cracked in appearance. I suspect that the same process will take place with the orange walls.
Spirit Offline OP
Donald, you are correct, the color is far from a true orange.
I like your analogy of an old rubber band.
scared
Try cleaning them with Cif (used to be Jif) watered down lifts the colour off slightly onto the cloth but does restore the orange a fair bit. Don't go to near the edge of the orange strip as it smears easily.
The second set of tyres I purchased via fleabay (Mr Whitewall) are much more deeper orange in colour.
If you have just one spot that's rubbed off, why not just reverse the tire so the bad side is on the inside?
It's still visible, but the chance that the blemish is under the inner fender is pretty good and you'll not see while moving...
Do a touch up as good as you can and my guess is that it will not show too much, if any.
If the orange is truly painted on like's been said, whitewall cleaner will probably not be good on the paint either.
Good luck though and let the guys know what you did to fix it.
Dan
Mine have only got the orange stripe on one side.
Dab,
Sorry about my assumption that they were orange both sides.
The first one was the one that lead me to believe that they are orange on both sides, but then after reading your reply, I looked in my picture archive and found the second one.
Dan
Originally Posted By Dan_Lockwood
Dab,
Love the second one...that's my "Bitch" love
I thought the tyres looked brilliant when painted on both sides, lost it abit when they produced them only on one side, nobody ever did come up with a reason why the stopped producing them painted on both sides, shame really.
The bean counters have been at work again to save a few bob.
Page 2 of 4 1 2 3 4
