1 members (Alan Patterson),
178
49
Topics49,846
Posts837,382
Posts: 389 |
they remapped the old engine 154 instead of 145 hp The conversion for the twoseater from kw to bhp is not correct. 106kW are 154bhp not 145. On the 4seater website the conversion is correct. Christian Sorry. I had the wrong scale in mind (1,37 PS per kw, what is definitly wrong). The others are correct. 154 HP are 113kw. So the 4 seater Website is not correct. Christia
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Er no! I think it is the other way round 106 KW = 144,12 PS and 142.15 BHP
Posts: 375 |
Regards 2005 PLUS 4
Posts: 36 |
Alpine a110 GT
Posts: 1,642 |
The revised model features the same 2.0-litre Ford Duratec engine as before but develops 154bhp and 148lb ft, an increase on the current car’s 145bhp and 140lb ft. Much of the power increase comes from an ECU remap that is the first ever developed by Morgan itself.
Is this right? All info here was that the +4 had a different engine, not just a remap of the current engine's ECU.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
TBH it is a mild evolution of old stuff, perhaps an interims solution. I thought they would install a new generation of engine on the Plus 4.
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
The pictures provided by Clipper show a specification board listing the 2.0 GDI?
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Sorry wrong source, not Clipper but from the web.
Mark
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
So maybe Aero Racing will offer an ECU remap? A lot closer to home for 'us northerners'!
Posts: 389 |
Information by MMC Website new Plus 4 Engine Ford GDI 1999cc Gearbox Mazda 5 speed Max Power 106 kw (145 bhp) @ 6000 rpm Max Torque 187 Nm (140 lb/ft) Performance 0 - 62 7.5 seconds Top Speed 118 mph (189 kph) Power to weight 165 bhp / tonne Urban mpg 28.5 mpg (9.9 l / 1 00) Extra urban 53.3 mpg (5.3 l / 1 00) Combined 40.4 mpg (7.0 l / 1 00) Co2 164g / km Length 4010mm Width 1720mm Height 1220mm Dry weight 927 kg Homologation eu Fuel tank size 55 litres Chassis Galvanaized steel
Specification old Plus 4 (German dealer Website) Motor Ford Duratec 2.0 Getriebe Mazda 5-Gang Leistung 106 kw (145 PS) @ 6000 rpm Drehmoment (Torque) 187 Nm Beschleunigung 0-100 km/h in 7.5 Sekunden Höchstgeschwindigkeit 190 km/h Verbrauch auf 100 km Stadt 9.9 l, Land 5.3 l, Kombi 7.0 l CO2-Emmission 162 g/km Maße L 4.010 mm, B 1.720 mm, H 1.220 mm Trockengewicht 877 kg Tankinhalt 55 Liter
The specification are mostly identical only the weight of the new Plus 4 is 50 kg highter. I guess MMC did not plublish (or know) the correct specification of the new engine otherwise the "more powerful new Plus 4" would be less powerful because of its higher weight.
Christian
