1 members (Carbuilder), 373 guests, and 28 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
#185728 10/03/14 03:44 PM
Jeremy Offline OP
After two great drives last weekend, noticed taht have some serious squeeks on the steering column when I turn teh wheel, is it something to be worried about or not?
Jeremy. Which model?
Bud
4/4 "Stanley"
Normally dry top bush which can drip if you oil too much or if your lucky its squeaking where the column passes through a rubber grommet on the bulkhead. Lift the bonnet that side, open the door, rock steering a little and see if the noise is noticeable under the bonnet. I use Vaseline (petroleum jelly) on the rubber as that lubes it without destroying it......if your brave ask the chemist for KY........running away now
BR Colin
In my Volvo, it usually means I am low on power steering fluid....
'67 +4 tourer - broken white - RHD
Jeremy Offline OP
To answer the question it is a 2006 Roadster
Jeremy
Spanner Juggler's post is probably the issue, but also just check that the back of the steering wheel is not rubbing agaisnt the cowl.
Bud
4/4 "Stanley"
Jeremy Offline OP
After a conversation with BHM they seem to be aware of what I need to do. It appears not to be a problem so possibly a trip to Wales for the weekend is on the cards. Will ask them to check it when I get back
