Posts838,003
Posts: 83 |
After two great drives last weekend, noticed taht have some serious squeeks on the steering column when I turn teh wheel, is it something to be worried about or not?
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
After two great drives last weekend, noticed taht have some serious squeeks on the steering column when I turn teh wheel, is it something to be worried about or not? Jeremy. Which model?
Bud 4/4 "Stanley"
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Normally dry top bush which can drip if you oil too much or if your lucky its squeaking where the column passes through a rubber grommet on the bulkhead. Lift the bonnet that side, open the door, rock steering a little and see if the noise is noticeable under the bonnet. I use Vaseline (petroleum jelly) on the rubber as that lubes it without destroying it......if your brave ask the chemist for KY........running away now
Posts: 297 |
In my Volvo, it usually means I am low on power steering fluid....
'67 +4 tourer - broken white - RHD
Posts: 83 |
To answer the question it is a 2006 Roadster
Jeremy
Spanner Juggler's post is probably the issue, but also just check that the back of the steering wheel is not rubbing agaisnt the cowl.
Bud 4/4 "Stanley"
Posts: 83 |
After a conversation with BHM they seem to be aware of what I need to do. It appears not to be a problem so possibly a trip to Wales for the weekend is on the cards. Will ask them to check it when I get back
