0 members (), 268 guests, and 40 robots.
+8Rich 90
Topics49,841
Posts837,323
Christoph
Page 9 of 13 1 2 7 8 9 10 11 12 13
Q
Q
From europa specialist spares ltd
Stock code 224011000280G
Vdo dip pipe sender 280mm £38
Q
Q
Just before installtion
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps8d58d768.jpg.html][/url]][/url]
For those of us in the UK, we should add 20% for the dread Value Added Tax!
Does anyone know if the existing short tube can be modified? It may save some money if not too expensive eg cost up to £15 or so.
HJP Offline
Nice to see the cable now encased in a trunking and neatly clipped , mine is stuffed between the gauge and the wooden frame and was chafing away until I protected it .
Hugh
HJP,
What's your build number, last three of serial number ?
thumbs cheers
2013 M3W # 793
'Mosquito'
Don't forget to remove the little pin that holds the float stationary during shipping.
HJP Offline
Hi Seeker ,
The number stamped under the seat is 334 , on the rear wooden frame it's 268 .
Hugh
Hugh
Q
Q
Yes thanks.i removed the pin
Paul, having changed my 250mm sender for a 280mm one, I don't think there is a cheap or easy way to modify the original unit and be confident about it sitting in the petrol tank. Tempting as it may be it's not the best place to be trying things out...... I cannot understand why Morgan still fit a 250mm unit, other than it gives you about half a tank "reserve".
Originally Posted By HJP
Hi Seeker ,
Hugh
Hi Hugh,
We've been finding those numbers are just a curiosity; my under seat frame number is 712, wood ash frame, 752. Production number 793 (last 3 of serial #), May 2013 build. I thought we might be close by production numbers ... guess not thinking
Conrad
Tally Ho!
thumbs cheers
2013 M3W # 793
'Mosquito'
