6 members (Dougie, DavidR, Mogdavid, RichardV6, BobJ, SteveMerch), 336 guests, and 40 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,344
Members9,215
#185720 10/03/14 03:11 PM
TimG Offline OP
I want to improve the internal lighting on my instruments. Paul Goff http://www.norbsa02.freeuk.com/goffyleds.htm does LED bulbs for instruments. Does anyone know the required fitting? To remove the instruments do I just undo the 4 socket head screws on each one?
TimG #185723 10/03/14 03:31 PM
On page 47 of the 2011-2013 parts manual it shows just a rectangular hole in the dash and the four corner bolts holding it all in.
I would be carefull of the wiring harness and not pull on anything too hard. I would think that they would leave enough play in the harness to remove it from the dash before unplugging all of the plugs etc.
Good luck.
Dan
TimG #185736 10/03/14 04:17 PM
I trust you are aware that the instrument lighting level is adjustable through the indicator stalk button menu TimG? It goes from 1 to 10 and 10 is pretty bright. I have found about level 6 is OK.
I wasn't, although I think I knew there was much magic (and potentially, damage) to be done in those hidden menus. If there a quick crib-sheet around for the 'keystrokes' somewhere?
TimG #185743 10/03/14 05:19 PM
TimG Offline OP
Planenut I was not aware of this function, I know pressing the black button on the end of indicator stalk cycles through mileage, trip distance, clock & voltage. How does the instrument lighting level work?
Tim
TimG #185760 10/03/14 06:12 PM
Toys for Boys
Toys for Boys
Tim, I'm with you, the only thing in the comprehensive manual is setting the clock!
Planenut spill the beans!
Omne trium perfectum
TimG #185777 10/03/14 07:28 PM
I only found the secondary menu by having a play when trying to find a speedo caliberation function, that I didn't manage to find, some VDO instruments do but not these. I am not sure about all the functions of the indicator stalk but the backlight level can be accessed as follows: Turn on the ignition, press the indicator button until voltage is shown, press and hold it until "ILL" is shown then press it quickly so it cycles through the different levels (lights on) between 1 and 10. You can set the level with another long press of the indicator button. Other than maybe messing the clock time up I don't think there is anything that will "end the world" in the secondary menu but I could be wrong! Good luck
TimG #185791 10/03/14 08:25 PM
HJP Offline
Thanks for that , I'll have a go at adjusting mine tomorrow as they are very dim .
Hugh
TimG #185793 10/03/14 08:32 PM
Thanks planenut - a good tip - will play with mine too!! laugh2
Neil
TimG #185844 11/03/14 06:30 AM
TimG Offline OP
Thanks planenut I'll give it a go but car not kept at home, not enough space, so cannot nip out to try it. Many cars seem to have these undocumented display functions.
Tim.
