0 members (),
236
50
Old Book
Topics49,940
Posts838,604
Posts: 1,653 |
Lush, did you use sport black?
Posts: 1,338 |
Posts: 1,338 |
After every three 3 drive or so,i have tighten the spark plug caps with pliers,so annoying,,,check yours please
Posts: 1,562 |
A biker friend at the weekend recommended removing the screw caps and fitting bike plug caps instead of the stock ones - apparently they are a push on fit onto the thread section of the plug ( i.e. no screw caps ) and dont fall off or loosen. This applies to a certain make of plug cap - cant remember its name - AKG ?
Posts: 1,338 |
If you find the fit,post a link,because checking on them after every drive isnt efficient
Posts: 206 |
Posts: 400 |
My left spark plug cap comes off every once and a while. Makes for a pretty spectacular noise. Havenīt figured out how to tighten without damaging the rubber - how do you do it?
M3W, now!!!
Posts: 1,562 |
Posts: 1,338 |
Sorry i meant the caps on the spark plug itself,but if the factory wire caps come off,look inside them,try to tighten the metal inside that clicks on the spark plug,gentle use pliers on them [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsc479a572.jpg.html]  [/url]][/url]
Posts: 1,338 |
If the ngk caps are good,try to email them with the spark plug number & if it can be installed on the factory cables.or do we have to order both the cap & cable from them?
