3 members (Taffmog, DaveW, Bishmog), 295 guests, and 100 robots.
+8Rich 76
Topics49,869
Posts837,665
Moggo
#152824 31/08/13 06:45 PM
Has anybody fitted Mulfab Hi Spec 4 piston calipers on his or her Morgan 4/4? I'm thinking about an upgrade for my 1990 4/4, and wonder if anyone has experienced this conversion.
Ruut Bianchi
Yes-I did it on my 4/4. Would highly recommend it.
Morgan 4/4 Sport Competition
I have no servo, that's no problem?
Ruut Bianchi
I did it on a 1981 4/4 with no servo. The pedal became lighter but with a little longer travel. The brake effect improved a lot. The only side effect was that due to lack of space the damper blades had to go and be replaced with the roller bearing conversion.
Harald
Harald
Soleng #152842 31/08/13 08:30 PM
Thanks a lot! I think I will go for it!
Ruut Bianchi
I think it should be possible to add servo if you decide you need it.
I decided to go for the conversion including adding a servo, keep you updated!
Ruut Bianchi
Soleng #167012 23/11/13 12:27 PM
Harald
Thanks for all the advise. I took the Morgan to my agent in The Netherlands (Klaaas Booij in Koog a/d Zaan). He will perform the upgrade to 4 piston calipers including adding a servo. I also decided to fit the reaction bars. According to Booij he sticks to the damper blades and don't recommend the rolling bearings, mainly for the expected shimmy. It should result in adding a steering damper, so he advised to keep the damper blades on my 1990 4/4.
We'll see what it brings!
Ruut Bianchi
The new Hispec 4 piston calipers fitted and some space found for a servo as well...
new Hispecs and servo fitted
Servo....
Not to much space....
Ruut Bianchi
Nice set of calipers there Ruut.
How does she feel under braking now ?
