3 members (JoeSpeetjens, Carbuilder, uvk33n), 297 guests, and 34 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,083
#186435 14/03/14 11:32 PM
I am in New Zealand and my master cylinder (U220008) has started leaking. Can anyone tell me where the master cylinder comes from OR a substitute for it. Thanks.
So, it looks as if no one knows. I think the master cylinder leak is a first on TM?
Depending on where the leak is, I would suggest a couple of options, though I'm sure you have already pursued these. No 1. is if it is a seal, then go into your local motor factors and try and match it, if it is the plastic resevoir, it will need replacing, and I suspect that any resevoir with a similar size would work, it's just a matter of finding one of the right size, again your local garage maybe? 3rd, email Morgan direct and get them to express freight one out to you.
Best of luck with it, keep us posted.
And..... oh yes, welcome to the forums Alan, I hope we'll be hearing more of your 'adventures', maybe enhanced with some of those great sky films of the Three Wheeler.
PJB Offline
Is there not a part number on the master cylinder? With that the manufacturer and hence supplier could be achieved. Can somebody access the master cylinder for a look see? Just a thought - PJB.
