5 members (lez, JoeSpeetjens, Hamwich, John Winn, JMcL), 293 guests, and 85 robots.
Sagging Hood
Topics49,859
Posts837,468
Page 3 of 4 1 2 3 4
Spirit Offline OP
Well it appears that MrWhitewalls.com is NOT going to respond to my emails; it has now been five days since the first one was sent – NOTHING!! banghead
So, it is now on to plan B; an attempt to get a color matched flexible urethane based paint made up by a paint and body shop. flyingpig
We’ll see how that goes; it should prove to be challenging I’m sure. sherlock
Past The City Limits
Is there an English Color paint store near you. That's we're I would go in Dallas.
2005 Roadster
2013 M3W
MOG South
couldnt you just order a new set of tires from the factory? With the orange "white wall" attached? Another option would be to clean the paint off all tires and make a new color of your choosing as the "white wall" either on your own or at a professional shop. Still, I cant imagine getting another set of tires wouldnt be a bad call especially considering down the road I am sure that another tire will get damaged.
Normaly the orange tyres are not sold by the factory
In France it is write on the order that the factory is not saling new tyres Only on the first delivery for the superdry And gulf model
Then as I mentioned, your best bet is to simply make your own color. Start fresh on all four tires and this way you would have the ability to make touch-ups at whim. Its nothing a good paint shop couldn't handle.
If you are worried about the prestige and history of the original set of orange walled tires as from factory, climate control store them and purchase a second plain set to have painted by a paint shop.
"Then as I mentioned, your best bet is to simply make your own color. Start fresh on all four tires and this way you would have the ability to make touch-ups at whim. Its nothing a good paint shop couldn't handle."
Two tires are enough
Spirit Offline OP
Success, I kind'a think = a definite MAYBE down here. cowboy
Here is Orange sidewall which I messed.
Here is Orange sidewall after first coat of color matched paint applied.
Not too bad, however still has some black shadow on the sidewall showing through.
I ran out of daylight, so had to stop working on it.
Requires a couple of hours to dry between applications.
Will apply another coat later on this weekend and then see how it comes out.
The color match is very close, but not exact.
It appears to be slightly brighter and very slightly more yellow than the original, but it may well be due to not having fully dried yet.
For others who need to touchup their Orange sidewalls the paint code is as follows:
Color is Diamont CM2-4611 made by R-M Paint which is a division of BASF.
It is available from auto paint suppliers that sell BASF paint products.
Q
Q
Good enough
Great thing
Thank you
Looks good to me!
Page 3 of 4 1 2 3 4
