SORN
Topics48,376
Posts813,555
Members9,215
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Very pleased it did its job!
We have 4, one in the downstairs hall, one in the upstairs hall, one in the spare room above the garage as it is a bit out on a limb and one in the garage over the main consumer unit and PV inverter.
The hall one used to go off quite often when SWMBO is cooking, recenlty changed it to one that uses a different technology and that seems to be much less sensitive to cooking fumes.
I also have a dry powder extinguisher in the kitchen by the door and a foam one in the garage.
Finally in the garage I have a 7lb ceiling bomb, it has metallic strips that melt at 165F and release sufficuent stuff to extinguish any fire in that space. Call me paranoid but I sleep better knowing that the Morgan is protected and the alarms will wake even me.
Battery change date is in the diary, all done the same day.
I firmly believe that it should be a legal requirement to have a working smoke detector.
Posts: 28,434 Likes: 183
Posts: 28,434 Likes: 183 |
Glad to hear the system worked and you are both OK.
I test mine regularly - usually with the toaster. Still haven't figured out why the alarm in the kitchen/diner area is a smoke alarm, rather than heat... And I have singularly failed to remove it from it's mounting to try to find heat alarm. All three are mains powered with battery backup. All fitted when the house was rewired a couple of years ago.
Reminds me, I have a battery CO alarm to fit...
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 979 |
Glad to hear you both ok  After 15 years of no alarms, just had ours replaced by our home security company.....better safe than sorry etc.
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
I believe it is for new builds and that they must be hardwired.
Richard 1976 4/4 4 Seater
Posts: 1,947 |
I believe it is for new builds and that they must be hardwired. Smoke alarms in Australia Not a legal requirement in the UK, and a normal one is useless for me. An alarm suitable for the deaf was quite expensive!
For all new UK dwellings, buildings converted to dwellings, loft conversions and dwellings that are substantially extended or altered the Building Regulations require that mains operated smoke alarms are fitted.
So about 15 years behind Australia...
Again.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
I have a classic story about smoke. Many moons ago, myself and MrsW were watching a late night horror - American Werewolf in London. It gets quite atmospheric when the scenes are on the moors with dense fog. In fact I turned to MrsW and commented that it was such a good film that it felt like the fog was in the room with us............ Then I saw the smoke coming under the kitchen door......... What had happened was that MrsW had decided to boil and bleach the dishcloth in a pan on the gas ring, and had forgotton about it. The pan had boiled dry and the dishcloth had gone black and was generating vast amounts of smoke. Thankfully once we opened all the windows to vent the air, there was no other damage.
Posts: 881 |
Thank you for all the your support been out today and replaced all the fire alarms. Ours are hard wired and and the fire brigade recommend to renew after a fire due to heat and smoke damaged
Very much in the dog house, could be up for rehoming
Posts: 7,076 Likes: 21
Posts: 7,076 Likes: 21 |
Just in case we need any reminding about the importance of smoke alarms... http://www.talkmorgan.com/ubbthreads.php/topics/159787/1I believe it is for new builds and that they must be hardwired. Smoke alarms in Australia Not a legal requirement in the UK, and a normal one is useless for me. An alarm suitable for the deaf was quite expensive!
Posts: 1,337 |
Glad no one hurt cleaning up is a real pain, been there etc but you were lucky.
After my incident I am over the top with alarms and extinguishers but next time if indeed there is a next time I will be ready.
I hope things get sorted quickly for you
Pete
