0 members (),
243
Posts837,992
Posts: 76 |
GRRRR!!!!! The rear reflector on my 4/4 sport fell off today whilst I was cleaning and polishing the car. This is the second one to part company as they are mounted onto an alloy plate that is glued!!!! to the underside of the rear wings.
I'm thinking of fitting ( bolting) small round reflectors mounted either side ( to the outside) of the fog and reversing lamps on the valance. Alternatively round reflectors affixed flat on the rear wings, just below the lights. Does anybody know if theses intended positions are OK within the law and if " round reflectors affixed flat on the rear wings" would be OK or should they be on the vertical????
Kind regards, Steve
Posts: 1,155 Likes: 2
Posts: 1,155 Likes: 2 |
The rear reflectors do have a habit of falling off from time to time ,clean the under side of the wing with thinners then use number plate sticky pads to put it back on ,that should last awhile . If you fit new reflectors then they must be vertical so use the plinths supplied by Morgan and the dealers as fitted to the currant car range of cars Simples!!!
Posts: 76 |
Thanks Peter, I'm not going to bother refitting the original + acquire a replacement for the one that fell off a while ago, but will mount some substitutes vertically as you advise ....
Kind regards, Steve
Posts: 358 |
It's now a 4/4 Lightweight
92 Connaught Green Plus 4 Triumph Bonneville 865
