8 members (+8Rich, sewin, Barkbark, Themorganeer, Morganmike, TBM, Guten, Luddite), 332 guests, and 100 robots.
+8Rich 79
DaveW 52
Topics49,866
Posts837,608
Page 1 of 4 1 2 3 4
I finally hit the 1000 mile mark and changed the oil in my bevel box.
I pulled the drain plug only to find nothing coming out, yes nothing!
I removed the fill plug and poured new gear oil in to see if it would run through and drain out. After a few pumps of new oil it made its way through and out the drain hole, although mixed with a murky nasty gooey gray colored fluid.
I had the whole machine elevated so I put the transmission in neutral and turned the drive shaft by hand. The dirty goo continued to drain.
I decided to try to get as much of the old goo out before filling with new oil.
I left the drain open then put the trans in 2nd gear. I started the engine and allowed it to run, spinning the drive train as I slowly pumped new fluid into the bevel box. I did this until the oil coming out was relatively clean knowing it would not be perfect.
I left it overnight to allow as much oil to drain as possible. The next morning I reinstalled the drain plug and filled the BB with new fluid. I used Royal Purple 85-140 synthetic gear lube mixed 60/40 with Lucas Heavy Duty Oil Stabilizer.
Royal Purple is a high quality lube and the Lucas product has additives for high heat/high load applications. It also causes the lube to cling to the gears and not be thrown off as easily.
After cleaning up and putting it all back together the wife and I took the M3W for a long drive to our favorite breakfast place at the end of 25 mile windy canyon road.
The bevel box noise was almost gone altogether, sounding more like tire whine on the open road than gear box noise.
My BB was not overly noisy to begin with but now it is almost not noticeable.
I did take time to properly break in my Bevel Box gears during the first 1000 miles so I think that helped a lot to make it quiet. I drove it easy and at varying speeds and always downshifting especially going downhill to allow the gears to wear in together both under load and deceleration.
I plan to perform the same service process after another 1000 miles then follow the standard service interval.
While I was at it I also changed the engine oil and filter. I used Mobil 1 synthetic oil along with the Lucas product. 5 qts Mobil and 1qt Lucas.
Maybe is was just my imagination but the engine felt smoother after our drive. It also seemed to start easier with less clatter during turnover.
The Lucas Product is recommended as a 25% replacement in Harley engines due to its heat stabilization, keeping the oil from breaking down. It claims to reduce wear under cold start conditions as it supposedly clings to the internal parts better thus providing lubrication before the oil pressure reaches the operating range.
I am usually skeptical of products that make grand claims, but so far I am impressed with this one.
Not sure if others would have the same results and in no way advertising for Lucas, but these were just my observations, thought I'd share.
And yes I know a running engine, spinning drives shaft, belt and rear tire are a dangerous way to exchange fluid in the BB. I did it with the utmost safety and I still have all my fingers!
DOG is my Co-Pilot
I had the same issue the first time I changed the oil in the bevel box. Nothing came out! So far, I've changed the oil 4 times and I still get thick black gunk when I drain it. Anyone know what the factory put in during assembly?
We may not be able to get the Lucas stuff in the UK but in the 70's & 80's I used a product with good effect called Slick 50.
I think it might be worth having a look at this again.
Slick50 - I remember that!! I think its still available - a lot of drag cars use/used it (?) read
Neil
I think Lucas are making product available in the UK - they have sponsored a few Stock Cars and Speedway bikes confused2 www.lucasoil.co.uk
Neil
PJB Offline
I would suggest that the lube is put in by Quaife not Morgan - wonder what it is. PJB
...and they are available on Ebay
Malcolm T
1966 +4
1957 TR3
1963 TR4
1983 LR 110
1985 Robin Hood 2.0l
Others seem to have had the same experience with their bb. Thanks for posting yours.
2005 Roadster
2013 M3W
MOG South
Available from Halfords:
http://www.halfords.com/webapp/wcs/store...1&langId=-1
Red Leader drive
After having had to fill the BB I realized why it may have been more or less empty. It is a time consuming, cumbersome process. I had a false indication several times that it was full. It looks like there is a long passage just inside the fill tube. If you fill too fast oil fills the passage and air can not escape from the box. Then the oil backs up and runs out making it look like it is full.
I ended up filling until over flow then putting the fill plug in and letting it sit a few minutes. Once the oil inside settled I repeated the process. When oil ran out of the fill port after it had a chance to settle I knew it was finally full.
I would guess that the kid at the plant was not as patient or thorough so as soon as he saw oil come out figured it was full and moved on to the next.
It should be one of the items checked during PDI. Why it isn't is a mystery. I would recommend any new owner check the BB oil before putting too many miles on their new toy.
DOG is my Co-Pilot
Page 1 of 4 1 2 3 4
