0 members (), 376 guests, and 39 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
#18568 07/06/08 01:46 PM
Andy Offline OP
I intend having my +8 serviced and have asked two dealers to quote for a 6000 mile/Annual service. Of course I have received two completely different answers (At least I wasn't asking two lawyers, then I would have three different answers). Anyway duration is either 2 hours or 6 hours with similar disparity in cost. Silly question I know but is there any experience/opinions on what should be included in such a service and how long it might take.
Thanks.
Andy
Andy #18778 11/06/08 01:04 PM
Andy, not really any help but when mine is serviced it takes a week! Working away from home (and the mog) means i take it to the dealer and leave it with them, collecting and dropping off on a weekend. At least then it saves trips back for parts being ordered etc.
Andy #18781 11/06/08 03:22 PM
The TM in Talk Morgan
Andy,
My understanding is that the service should cost between £400-500 (GBP). Length of time the dealer will want the car will vary but the service should take no more than 1-day; however, they may ask you to leave the car for longer to give them a buffer to order new parts should your Plus 8 need them and/or the job before you runs over.
What is included will vary slightly from dealer to dealer; however, as a base they should cover most, if not all, of the following: -
Check all the fluid levels (including diff)
Change oil and filters
Inspect the engine for any issues (leaks)
Check coolant
Check brakes and replace fluid (recommended change every 2-3 years)
Check the ignition timing on older cars (reset base idle if needed) - later Plus 8s there is no need due to electronic ignition
Check the car over - especially underside - for any loose or lost nut/bolts.
I'd say that is a good start; however, like a physical for a person, you can be as quick or as thorough as you want/deem necessary. If you are speaking with two dealers, why not ask them to review with you what you are getting for your money? smile
Andy Offline OP
Thanks for the advice. I have made the choice at the end of the day based on logistics. It does mean the car will be there a week which I hope will mean anything unforseen can be dealt with.
One other point. You mention checking the diff oil. Should it not actually be changed every 5000miles or will they be able to determine its condition?
Andy
