3 members (lez, John V6, JMcL),
158
79
Topics49,887
Posts837,880
Posts: 1,418 |
RB? Ross Braun?? Isn't he Mercedes then???  I'll stop now lest I get banned from Combe  Jeremy
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
I was thinking Richard Branson... But haven't spotted a Virgin Race Team
Posts: 2,361 |
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 2,361 |
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
Martin (Deano)
Posts: 486 |
Very nice Chunky I do like the new dash also loved the predecessor it's a shame it had to go it was so cool.
Is that one of the Extinguisher T Handle on the Left fitted in the glove box 'Lid'?
If so is it for you to pull or a Marshall or do you use the one in front of the steering wheel to the right? Just wondering if you can reach either of them when harnessed tight into the seat? If you are going to use left side T handle do you need to move it closer to bottom right of the glove box lid in the tight curve and angling the T handle to you/driver for a straight pull, would be ergonomic to reach for you and pulling is easier than lifting (even with all that free weight training when fitting Super flex suspension). Would it be permissible under the regs?
Cain
Cain
Wolf Cafe Racer 4/4 Sport
Posts: 2,361 |
Cain
The glove box fire extinguisher pull is for the marshals, yes once tightly strapped in you can reach and pull the right hand side extinguisher pull.
Posts: 2,361 |
So over the last couple of weeks of I've had the final 2014 regs through and me being me needed to keep pushing the boundaries, but I've checked and this is legal. I've been playing about using the suplex idea but using a higher rated 2.25" coil spring. I've tested the spring tension and worked out the spacer size I needed. The spacer size is different each side due to where weight is in the vehicle.  Then I finished off tidying up the roll cage
Hi Laurie
Could you indicate the sort of advantage the suspension spacer will deliver?
Martin (Deano)
