2 members (+8Rich, kiwi100),
156
63
Topics49,886
Posts837,857
Posts: 2,361 |
Hi Laurie
Could you indicate the sort of advantage the suspension spacer will deliver? Where normal suplex is adjustable for tension on the compression spring, in the aero race series this is only allowed if you use 1.9" original Morgan size compression spring. As I use a 2.25 shorter and higher poundage spring, I have to keep it fixed non adjustable.
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 5,659 Likes: 10
Posts: 5,659 Likes: 10 |
Hi Laurie
Could you indicate the sort of advantage the suspension spacer will deliver? Where normal suplex is adjustable for tension on the compression spring, in the aero race series this is only allowed if you use 1.9" original Morgan size compression spring. As I use a 2.25 shorter and higher poundage spring, I have to keep it fixed non adjustable. Very Clever, thanks
Martin (Deano)
Posts: 2,361 |
Hi Laurie
Could you indicate the sort of advantage the suspension spacer will deliver? Where normal suplex is adjustable for tension on the compression spring, in the aero race series this is only allowed if you use 1.9" original Morgan size compression spring. As I use a 2.25 shorter and higher poundage spring, I have to keep it fixed non adjustable. Very Clever, thanks No worries. I like to keep the upgrades coming on this lady.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 2,361 |
Always
Posts: 1,418 |
Good luck for Saturday guys. Keep it on the black stuff and ahead of the other "E"s.
Jeremy
Posts: 2,361 |
Jeremy Thank you Jeremy
