Topics49,847
Posts837,391
Posts: 462 |
Beautiful. Adjustable lenght (easy to do, 1 or 2 inches) would make them perfect as a commercial product for classic Morgans of any year.
1967 4/4 1500 Comp. 1935 Super Sports Barrelback
Posts: 14,009 |
I've just been in the garage doing some work under the bonnet.....and these stays really are a delight to use!
Posts: 486 |
Very tidy, Cain- you'll have to put an ad in 'Miscellany'. Gerry. That was going to be one of the steps forward, along with front and rear valances but there still not quite how I want them! Cain
Cain
Wolf Cafe Racer 4/4 Sport
Posts: 486 |
Beautiful. Adjustable lenght (easy to do, 1 or 2 inches) would make them perfect as a commercial product for classic Morgans of any year. You have a PM sir!
Cain
Posts: 1,502 |
I can't see the photos in the original post - other photos are working ok. Perhaps a link would help? Interested too. Nigel
Posts: 14,009 |
Posts: 24 |
I used a ball joint throttle linkage secured at rear latch point with an aluminum rod threaded to it. Put one of those replacement rubbers for your pencil on top to prevent slippage. A little fine steel wool polished the rod to a high gloss.Low cost fix. No more broom handle.
Gordon
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
I've used aluminium tube from Wickes with handmade brackets at either end. They sit on a shelf in the garage when not deployed.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
John, Cain was very helpful. A set are in the post. John
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I've just fitted them: not difficult but care needed. The only slight concern, and this applies only to a V6, is that the gap between the parked stay rod and the cam cover is really small, this makes it clear.... As the motor does move I have some concerns...
