6 members (B3MOG, Wouter, John Winn, JohnHarris, Graham, G4FUJ, RedThree),
181
Topics49,901
Posts838,042
Posts: 417 |
would love to see the go pro footage from mark's run as i found a pic online of him doing the run solo with a go pro on the roll bar.
blake sfmorgan.tumblr.com
Posts: 14,009 |
Blake, I think you just might see the top of a helmet on the passenger side! How Joanne squeezed down so far is a mystery!
Posts: 983 |
She must have been on CoG training!
Philip.
Posts: 3,564 Likes: 13
Posts: 3,564 Likes: 13 |
Why do the factory continue to fit short senders? Anyone had an answer? I carry a spare gallon in the back now, just in case I don't fill up in time, it will give me another 30 miles to find a fuel station.
Great to see those photos of the Three Wheelers doing their stuff, thanks for putting them up.
Posts: 1,461 |
My first car was a 1932 Austin 7*. It had a five-gallon, petrol tank, in front of the scuttle, that fed the carburetter by gravity. There was no fuel gauge; instead there was a rather fine calibrated dipstick. I wish the M3W were so equipped - it may have been crude but you knew how much fuel was left. *No, I did not buy it new.
Posts: 1,947 |
You can always make your own calibrated stick. I did for the two speeder, but a three and a half gallon tank contents is pretty easy to put in cans and replace with a measuring jug, marking the stick as one goes.
Posts: 14,009 |
You might need a forked stick with the twin tanks of the new three wheeler!
Posts: 1,461 |
You can always make your own calibrated stick. I did for the two speeder, but a three and a half gallon tank contents is pretty easy to put in cans and replace with a measuring jug, marking the stick as one goes. I expect the fuel tanks on the old 3 Wheelers were similar to that of the Seven - a rectangular box with a screw-cap on top. Alas, things are not so simple with the modern 3 Wheeler... [Edit] You beat me to it, Jays!
Posts: 6,538 |
anyone know info about Mark Reeves "bigger engine"? Great set of pics - makes me want to start Hillclimbing again!! I drove Loton a lot - always found it a tricky challenging course - and only ever made mid class!Drove it in my Westfield and my Jedi:))
Neil
Posts: 1,562 |
anyone know info about Mark Reeves "bigger engine"? Great set of pics - makes me want to start Hillclimbing again!! I drove Loton a lot - always found it a tricky challenging course - and only ever made mid class!Drove it in my Westfield and my Jedi:)) Chatting with Mark at Curborough, he said it was a different engine in the S&S range than fitted as standard , slightly bigger capacity ( 2.2L I think ) and hence bigger HP. Fitted with the sports pipes it sounded awesome - deeper growl and roar.
