7 members (Hamwich, SteveT, tezzer, MartinB60, Graham, G4FUJ, TeddyAds, BLUE+4), 341 guests, and 83 robots.
Topics49,848
Posts837,399
DazMog, The Impaler, tlchzj79
Page 1 of 6 1 2 3 4 5 6
#201618 30/05/14 05:23 PM
Z
Z
Got my Empire bits back from anodizing and I've started the install. I'm looking forward to posting a driving report but I'm not there yet and they are forecasting heavy rains for the next few days. So I will have un-rushed tweak time and the ability to really over-analyze every aspect of it.
As a designer of mechanical things, as well as, a owner of a big manufacturing facility, I feel I am qualified to pass judgment on the manufacturing aspect of the Empire kit thus far. It is no less than stellar from the manufacturing stand-point, as well as, fitment. The machined parts, though difficult to design, are the easiest to build to close tolerances. However, the welded bits are what I am most impressed with. The angle on each is just right and very little distortion after removed from the fixtures.
Surprisingly, the slip-fit welds are "fish mouthed". This accomplishes three things...1) it provides for more linear weld thereby making the joint stronger, 2) it keeps the weld from being in a single plane thereby reducing the chance of cracks or breakage due to embrittlement from the application of localized heat and 3) it tells me who ever designed this kit knows what he is doing. Subtle but a tell-tale hints (like the absence of stress risers) of the kit as a whole.
The big aluminum "spacer blocks" (for the lack of a better term...black anodized)are a close fit in the Morgan chassis. On the left side of my car, it looked like the "block" wasn't going to fit but taking a different approach to entry into the tabs of the frame and holding my tongue just right, they slip in without resistance...very close but accurate fit.
On my rainy day schedule, I plan to explore camber and castor now that it is an option. With the amount of castor that was in the car as delivered, I suspect it was disguising the bump steer issue to some degree.
Before starting this work, I took some measurements of castor (BTW, not the same from one side to the other on my car) and while working the car up and down on jacks, it was very obvious to the naked eye going from unloaded, to neutral, on to a loaded or compressed suspension...the steering went from toe out, to toe in, back to toe out. Not ideal under any circumstances. Now with the upper A-arm hinging in the same vicinity as the tie rods and with the tie rod ends elevated almost parallel with the upper A-arm, maybe I won't have to re-cover my lower seat cushion after all.
As a side note, the bolt-in brace behind the engine showed a little sign of bleeding rust (on the upper end in the pic)...a sign something is loose and moving. True to form, it was far from being tight on that end.
I have decided to take a different approach to my M3W. I have been "sympathetic" toward the car and have tried to drive it in a manner to prolong the onset of the multitude of problems that can and most likely will arise. It's killing the joy of the drive. I have decided to just go ahead and run the hell out of it and fix it when it breaks. Eventually and maybe with the help of some non-OEM parts/fixes, maybe I'll have the reliable little car I thought I was buying.
Z
Good feedback - many thanks!!:))
Neil
Being non-english native, can you explain the phrase "slip-fit welds are "fish mouthed"
1) Can you elaborate a little on camber and castor adjustment as i am going to install the kit on Monday next.
2) How "easy" was it to get access to the bolt of the upper wishbone hidden by the bodywork?
Thanks a lot
great write up. would love to see more pics of the setup both close up and far away.
blake
sfmorgan.tumblr.com
Nadvys--That bolt is a real bugger. I took a metric (Taiwan) metric wrench and flattened the box end and bent the wrench (spanner) to a right angle. I then glued the nut into the box with the washer and the operation went slick after that. The time was spent in thinking about it and modifying the wrench. PaulJ said he was able to reach up somehow from under the car. Good Luck
I can reach in with the open end of a combination spanner. getting the nut back on just needed a bit of duct tape to hold the nut in the open jaw of the spanner. Its awkward but not too bad.
Be careful on my chassis (late 2013) on the left side there is an exposed positive electrical connection. Since discovering this I make a point of disconnecting the battery before going in about this bolt. Didn't blow any fuses though.
I fitted my Empire kit this evening, 3 hours start to finish.
Tomorrow I will do final adjustments and road test weather permitting.
A little trick I use when I have to hold a nut into a tight place, don't go there guys, I know what you're all thinking, I put a piece of masking tape on the outside of the open or box end of the wrench and just push the nut into the wrench and the tape holds the nut in place long enough to get the bolt started, usually that is.
If I need to do something with a washer, like to add it to the underside of the nut, I use a bit of heavy grease and it will stick to the nut long enough again to get them in place.
I also have a large selection of wrenches that I've heated with the torch and bent for so many different applications. I keep odd brand wrenches around just for that purpose.
It sounds like we have several with the kits about ready to road test. I enjoy reading all the testing and installation bits and pieces.
You guys all have a great weekend.
Dan
Ah, optimism. That's good.
When you can see adequately, you won't need to do this but putting a nut in an awkward spot, turn it the wrong way until it clicks - then stop and turn the right way. Puts paid to cross-threading things!
Perhaps I'm teaching granny to suck eggs, but most of us don't get workshop 101 and learn on the job.
