4 members (JohnHarris, Paulxj, Clipper, TrickieDickie), 288 guests, and 93 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
Page 2 of 6 1 2 3 4 5 6
"Perhaps I'm teaching granny to suck eggs, but most of us don't get workshop 101 and learn on the job."........
hey guys, whats a little workshop time in comparison handling a woman????
Great write up. Thanks for sharing.
Question: What problems with the front geometry does the empire kit fix?
Do you have to have Suplex shocks to feel the benefit of the kit?
Is the Empire kit compatible with an already installed comfort kit?
Thanks,
Roland
1. Everything.
2. No, but Suplex or Spax dampers will give a better ride.
3. Yes.
Some photos.
installed one side of Empire Kit today. Not that easy because of body work blocking access to aluminium billiet. But we managed with some pushing and shoving...
@ Dap of Oppo, did you change the steering arms ends yet? Can't see them on the picture. They look like the original ones?
Thanks for the photos and the information sheet. Does Empire include baseline setup instructions?
Roland
I have lowered the ride height by 30mm so don't need the risers. Have a look at my second photo you will see my steering arms are horizontal.
You have made my first mistake as well.
The rear wishbone bolt is the wrong way round.
If you leave it like that you will not be able to adjust the rod end to achieve the correct geometry.
I did the first side like that and had to strip it down again and re-fit it the same orientation as the front bolt.
Hi Nadvys,
Did you get the new risers in till the end ?
The ones I have do have the same size tapered end als the old ones but don't go in all the way.
Will check out more tomorrow.
Laurens
www.m3w-jungfrau-treffen.com
