5 members (deano, Vansrv6, rory kim, Graham, G4FUJ, SCX358G), 192 guests, and 31 robots.
+8Rich 100
John V6 66
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
Factory meet
Mog Mags
by Lord Sward - 20/09/26 01:44 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,937
Posts838,564
greenteagod
DaveW Offline OP
From new Bob it will have been edged properly.
Thank you DaveW, it does look OK.
Best Regards
Lang may yer lum reek
Looks like some serious cleaning to be done Dave.
Yellow is a magnet for flies.
I had a bright yellow motorbike once and was coming back from Thruxton one Summer's evening with two friends.
One bike red and white, one bike bright green and mine; on getting back to Exeter, my yellow bike had approximately twice the amount of dead flies on the fairing, in comparison with the other two.
Nasty
Bud
4/4 "Stanley"
Nasty
Thats because you were driving twice as fast. grin2
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Yellow is a magnet for flies. Does that apply to Yellow Submarines as well?
Best Regards
Gone to Porsche
Gone to Porsche
Apparently a Fly can deflect away from an oncoming missile (car) if it is not exceeding 53mph!!!!!!!
Now what is the last thing to go through a Flys mind as it hits your car ?
It's ars of coarse grin2
DaveW Offline OP
And here's the cover for the main cable grommet. An offcut of aluminium, with a neoprene curtain. And with an extra grommet around the steering column.
And here's the mods to the header strip. A circular section of neoprene with a 3mm strip below. Lets see how this goes!
Interesting as ever Dave.
DaveW Offline OP
Post Photobucket Re-Boot.
The first bonus, post-Scotland was to find that no water got under my shield into the cam covers and plug holes.
Here's how Mr Bumble looked when we arrived home........
The flies were thicker than they look in the photos.
We had some leaking through the bulkhead. Here I've added a neoprene washer under the plastic cable clip.
Around the throttle cable, there's a large hole through the bulkhead, which has been discussed before. Here I've fitted a U shaped aluminium shield edged with neoprene at both ends.
I've also pushed a small piece of neoprene into the open corner edge on the bulkhead, which is just visible.
The next job was just my OCD emerging. The drivers side carpet was quite scruffy after the trip. When you fit an organ throttle pedal the carpet has to be cut around the base and this leaves it untidy. I strengthened the rear at the time with some silver gaffer tape, but now was the time to sort it.
Here it is 'as was'.
And now with extra leather edging, and the rear strengthened with leather. I also removed the scruffy rubber heel mat, and replaced it with a new offcut, held in place with four soft top fasteners so it can be taken off for cleaning.
