1 members (JoeSpeetjens), 328 guests, and 38 robots.
+8Rich 94
Posts837,276
Page 5 of 34 1 2 3 4 5 6 7 33 34
HJP Offline OP
Originally Posted By Matty
Good news
Has the factory indicated why the chassis failed?
I presume the crack was due to flexing , hence the various stiffening modifications with the welded in bracing of the 2014 model being the ultimate version .
I have done more miles than most people at over 10,000 miles and a lot of it on bumpy roads , which probably explains why I found the bump steer worse than others .
I regularly drive on the A1101 between Mildenhall and Littleport which is a seriously terrible road , how it can be classed as an a road I don't understand ! If anyone wants to test the suspension on any car they should try it . It's not exactly a scenic route unless you are particularly fond of fenland views !
Hugh
Just found what looks to be start of crack on my May 2012 3W.
about 8 mm long and radiating out from top and rear near side suspension lug.
I have done 6300 miles. Will call factory Monday
See pic
Shall we add a special field in the M3W registry to keep track of the chassis with problems? shades
sorry to hear about the new discovery Matty, keep up posted
blake
sfmorgan.tumblr.com
Thanks. Will do. Phone call to Malvern 9 o'clock Monday morning.
I don't want to miss the summer.
Sorry to hear about your latest problem with the chassis Matty. Hope it is sorted out for you ASAP. As you say, you don't want to miss out on the summer.
Good luck Matty.
Will let you know tomoz
Are you allowed phone contact with the factory and get an answer from them? My dealer (non UK) did not get any response from the factory until he duly sent in a email with technical support request.
This joke has been going on now for nearly 7 weeks for a broken valve spring and last week factory sent out all needed spare parts except spring.
Did we say "improved customer service"?
