8 members (TalkMorgan, Image Library, John Wilcox, TBM, Doug J, Nick55, Gambalunga, Michael Harding),
262
Topics49,911
Posts838,147
Posts: 1,502 |
Can anyone kindly provide a step by step guide to flushing the cooling system on my black top zetec 4/4? And is it worth using a flushing product such as the 2-step Holts liquid? I'm pretty sure it's never been flushed (2005) despite full service record. Many thanks, Nigel
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Normally...
1. Add flush as per manufacturer's instructions. 2. Run engine to temp and/or time specified. 3. Allow engine to cool. 4. Remove lower hose and drain coolant, remove reservoir cap. 5. Replace lower hose. Refill coolant. 6. Run to temperature with reservoir cap off until all air is expelled. 7. Replace cap, go for a run and check level on your return.
You can also run a normal garden hose in to the radiator after 4 and hose it around. Same from the reservoir cap.
Richard 1976 4/4 4 Seater
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Dont foget the ANTI FREEZE this ain't OZ it's England. Normally...
Dont foget the ANTI FREEZE this ain't OZ it's England.  How quickly one forgets
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
It might also be worth disconnecting the heater hose to flush that with a garden hose.
ALSO have the heater turned on an turned up to full heat when bleeding the system in step 6....
Posts: 1,947 |
Actually you need a corrosion inhibitor whether it freezes or not in your country. Antifreeze is a convenient carrier for this, although if you are determined, you can get corrosion inhibitor on its own although usually in silly quantities as central heating system additive. One trade name is "Fernox".
I just just premixed coolant....removes all effort. Lazy, its true but for the small price difference when on offer.
Posts: 1,502 |
Specifically for the black top Zetec, where is the thermostat? I can't see one.
Posts: 2,781 Likes: 5
Posts: 2,781 Likes: 5 |
Back of the cyl head, black plastic housing which I think on earlier zetecs was prone to cracking. Steve
Steve 2008 4/4 1.8 Duratec
