6 members (sezznowt, Morganmike, RichardV6, teknome, Biggle, Cerberas), 220 guests, and 66 robots.
+8Rich 75
Topics49,861
Posts837,534
Jonny72
#204564 16/06/14 11:56 AM
Hi,
Anybody know what the front trunnions grease nipple size is on a 2001 4/4 Zetec black top. I need to change them to a 90degree right angle version to availed the shock absorber when greasing, access is impossible at the moment. Also where can I purchase them.
Thanks
Phil
Regards
Phil
2001 4/4 Red
I bought grease nipples from Holden, but can't remember the size.
Just as on your car my right hand side nipple is very difficult to grease.
It's easier to grease if I turn the steering wheel slightly to one of the sides.
And I don't jack the car up, as this brings the shock absorber closer to the grese nipple.
4/4 2 seater 2001 model
Thanks Geir,
I've tried what you say but still can't get the grease gun aligned. I was wondering if there is an attachment I can fit to the grease gun.
Thanks again
Phil
Regards
Phil
2001 4/4 Red
It's much easier with a flexible hose on the grease gun. You'll get the grease nipples from any agricultural machinery supplier. Just take an old one in so you get the correct thread.
1972 4/4 2 Seater
Formerly known as Aldermog
And even easier still if you take the wheels off...
Phil
It will probably be ¼ inch UNF. The remote greasing kits supply M6/UNF/BSF nipples for the stub axles. The pitch difference is only 26 tpi to 28 tpi (UNF is 28) Try www.lubetec.co.uk for 45Deg hydraulic nipples.
I fitted the UNF to my 2001 Y reg 4/4 Zetec with no problem. GOMOG and Morganatica have good information.
David
David,
Thanks for that - really useful info.
Phil
Regards
Phil
2001 4/4 Red
