2 members (ChrisConvertible, Pittsartist), 211 guests, and 60 robots.
+8Rich 76
Topics49,863
Posts837,545
Page 3 of 3 1 2 3
MGDave #207054 28/06/14 12:10 PM
Hi Dave, looks a great deal on your battery. Regarding the wiper blades I believe the subject was covered earlier this year and the suggestion was that the blades could be sourced from a Land Rover dealer and the cut to fit.
If you have a dealer close to you it my be best to take one along to ensure the attachment matches your Wiper arms.
Ian
MGDave #207173 28/06/14 07:18 PM
Great without bumpers thumbs
Alpine regards
Morgan 4/4 Sport 2012
Mini Cooper S 2017
Morgan 4/4 70th Anniversary 2006-2015 prev
MGDave #207175 28/06/14 07:21 PM
VW beetle blades also apparently work
MGDave #207985 02/07/14 10:06 PM
MGDave Offline OP
My quest to get the car on the road took a step backwards last Saturday, the man at the ministry (license office) was unable to recognize the Vin #, something to do with the number not being in the system. In the meantime I checked out brakes, lights etc, unfortunately the only item not working was the hazard warning lights and clock, checked the gomog Web site for direction, it pointed towards the fuse block, after much searching I eventually found it under the dash,the Web Page said check fuse #8 for post 93 +8 cars, on my fuse block the fuse was missing, bingo I've found the problem. WRONG
I concluded that this slot wasn't used seeing that there was only one contact present. Back to the drawing board.
While changing the battery last week I noticed a live wire off the isolation switch terminal, the wire had an inline 10amp fuse hidden between the battery and the bulkhead so I removed the battery and found the blown fuse. Luck at last.
Hopefully I can get the Vin sorted tomorrow
Dave
98 +8 Corsa Red
74 MGB Red
MGDave #207999 03/07/14 12:42 AM
Good luck with the VIN Dave.
MGDave #208112 03/07/14 09:03 PM
Nice car Dave, there is always something to tax your brain on the Morgan, but there is always a big smile when you drive it.
Happy Morganeering.
Colin.
RX450 easier ezchair.
2004 Roadster.CM51ERS.
MGDave #208409 06/07/14 12:29 AM
MGDave Offline OP
Vin all sorted, time for our inaugural drive.
cheers
Dave
98 +8 Corsa Red
74 MGB Red
MGDave #208444 06/07/14 01:31 PM
Great to hear Dave!
Page 3 of 3 1 2 3
