0 members (), 295 guests, and 49 robots.
+8Rich 93
Posts837,277
#206425 25/06/14 11:18 AM
nadvys Offline OP
Chasing some noises, i noticed that my oil tank was very loose.
1) the braces are too big for the tank model and do not allow for enough tightening
2) the triangular support on the sides is very shabby and flexible which allows the tank to move quite a bit
pictures attached for better location.
Does anyone have this experience or are your oil tanks stable and not moving?
Tks
HJP Offline
Just had a look at mine . It looks basically the same , although I don't have the drain plug .Mine will flex around a bit if I push it , but the straps fit tightly and it feels secure .
Hugh
Mine is also pre-drain plug and is secure
As per Red 3 & HJP
Not the same for me
Mine is secure and pre drain plug. Although oil leaks out of hoses at the engine side at a rate of 1ml per mile.
