10 members (Barkingdog, linklaw, jeremylparker, +8Rich, 3-Rad, Craig Jezz, MartO, Image, TalkMorgan, Mogdavid), 283 guests, and 48 robots.
Topics49,845
Posts837,373
Page 3 of 4 1 2 3 4
Hello
I am in France ...
Is this kit marketed by morgan factory ? or a dealer morgan in USA ?
How can - we get it ?
Thanks for all
Denis
Talk to your dealer or did you get this direct from the Morgan factory? If so, talk to them.
Denis
It is a factory supplied kit so any dealer should be able to get it for you and to fit it. It's worth it; it makes a big difference.
Denis where are you in France
I am near Toulon
Bonjour
Sur la Lorraine (Nancy)
Je suis également parfois en Provence (Manosque)
Denis, spend a little more and order the Empire kit. The comfort kit helps but does only half the job, it doesn't make caster, camber adjustable.
I saw the parts of the kit " comfort " but of which consists the kit "empire"?
Is it the Morgan factory which sells it?
Originally Posted By denis3w
I saw the parts of the kit "comfort" but of which consists the kit "empire"?
Two points:
1) Although I have not driven a 3 Wheeler with the Empire kit, I am convinced that it brings a major improvement to the handling. Bill Chaplin is an expert.
2) It is not a factory option. I think it should be and perhaps it will be at some point, but you should check this carefully, bearing in mind the legal/insurance implications before fitting it and using it in France.
I've not driven a car with the Empire Kit either but I could not see spending several thousand dollars for it vs. less than Two hundred dollars for the Comfort Kit.
If this was a race car I could understand wanting to have camber / caster adjustments.
But........ for a 3 wheeled, underpowered car with a flexing / cracking chassis designed for driving down a country road on weekends.......it is overkill in my opinion.
DOG is my Co-Pilot
Page 3 of 4 1 2 3 4
