10 members (Robbie, Tweed19er, Morganmike, Themorganeer, tommog, Alistair, JohnHarris, Graham, G4FUJ, SteveT, rossocorsa),
183
59
Topics49,846
Posts837,383
Posts: 25 |
Hello I am in France ... Is this kit marketed by morgan factory ? or a dealer morgan in USA ? How can - we get it ? Thanks for all Denis
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
Talk to your dealer or did you get this direct from the Morgan factory? If so, talk to them.
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Denis It is a factory supplied kit so any dealer should be able to get it for you and to fit it. It's worth it; it makes a big difference.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Denis where are you in France I am near Toulon
Posts: 25 |
Bonjour Sur la Lorraine (Nancy) Je suis également parfois en Provence (Manosque)
Posts: 582 |
Denis, spend a little more and order the Empire kit. The comfort kit helps but does only half the job, it doesn't make caster, camber adjustable.
Posts: 25 |
I saw the parts of the kit " comfort " but of which consists the kit "empire"? Is it the Morgan factory which sells it?
Posts: 25 |
Posts: 1,461 |
I saw the parts of the kit "comfort" but of which consists the kit "empire"? Is it the Morgan factory which sells it? Two points: 1) Although I have not driven a 3 Wheeler with the Empire kit, I am convinced that it brings a major improvement to the handling. Bill Chaplin is an expert. 2) It is not a factory option. I think it should be and perhaps it will be at some point, but you should check this carefully, bearing in mind the legal/insurance implications before fitting it and using it in France.
Posts: 115 |
I've not driven a car with the Empire Kit either but I could not see spending several thousand dollars for it vs. less than Two hundred dollars for the Comfort Kit.
If this was a race car I could understand wanting to have camber / caster adjustments.
But........ for a 3 wheeled, underpowered car with a flexing / cracking chassis designed for driving down a country road on weekends.......it is overkill in my opinion.
DOG is my Co-Pilot
