Topics49,861
Posts837,540
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
As I am far away from my Morgan Dealer, is there a do-it-yourself-way for toe setting without professional eqipment? And what are good default settings for a m3w with Blockleys, toe neutral or toe in 1 degree?
Achim
Posts: 3,562 Likes: 12
Posts: 3,562 Likes: 12 |
it's a bit late tonight Achim, but if one of our American cousins hasn't come back to us by the morning, I'll have a go. Don't worry though, it's not difficult.
BTW, do you have the 'comfort' kit, or are you still in the stone ages? [I know you don't have the Empire Correction kit].
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
My dealer set me up with 0 degrees with the Blockleys. I have no complaints. I also have the 'comfort kit' installed.
As for the do-it-yourself way I think there are a few low tech ways to do it involving some boards and a tape measure. Google to your heart's desire...
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
I rule the clamp wheel with chalk and a laser level bubble and I trace dens ground two meters in front and rear wheels, I position the laser spirit level on top of the tires.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
You could do as molly . Laser fix on the disk break And after the same think off Glloq
Posts: 30 |
An easy way to set toe in is as follows:
Buy a length of aluminium angle or box, say 25mm x25mm. Cut 2 pieces twice the precise length of the wheel's diameter. Attach each piece with bungees from the rear edge of the tyre, facing forward, through the centre of the wheel (over the spinner). When both sides are set up, take your measurements....the measurement across the front edge of the wheel, will effectively be the back measurement, and the measurement at the end of the angle/box....a diameter measurement forward of the wheel will be where to take the second measurement, of for example, no toe in, or say 3mm toe in, 1.5mm per side. Keep the aluminium pieces in a safe place enabling measurements as required.
Posts: 508 Likes: 1
Thanks Merlin, after having found the translation of some of your words  , I will try it atalante: You could do as molly . Laser fix on the disk break And after the same think off Glloq Sorry, but I can't understand the words molly and Glloq, sorry for not being a native speaker  And PaulJ: yes I have the comfort kit, very happy with this
Posts: 37,418 Likes: 978
Posts: 37,418 Likes: 978 |
""Sorry, but I can't understand the words molly and Glloq, sorry for not being a native speaker ooo""
GLLOQ is the poster at 0610 this morning 3 posts before you, can't help with molly though.
GLOQ's post - "I rule the clamp wheel with chalk and a laser level bubble and I trace dens ground two meters in front and rear wheels, I position the laser spirit level on top of the tires."
Molly is MOl on the forum she made à vidéo about this subject.
