2 members (Ian B, ScotiaSteve), 310 guests, and 105 robots.
+8Rich 84
Topics49,860
Posts837,485
All my cars do that when you take the cap off. I am sure that is quite normal. You must have a leak somewhere which you have not spotted. Petrol usually leaves some form of trace, so it looks as if you will have to check the fuel line from tank to engine.
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
olive64 Offline OP
Thank you.
This time, I am going to inspect everything toff
Alpine regards
Morgan 4/4 Sport 2012
Mini Cooper S 2017
Morgan 4/4 70th Anniversary 2006-2015 prev
Just a little piece of info conerning replacement pipes. If your 4 is around the same vintage as mine there are TWO possible replacements, the difference being in the diameter of the steel pipe going into the tank. Both have a 60mm (approx) OD diameter at the filler cap, but later cars have a reduced diameter of 45mm at the tank end, earlier ones have the same as the filler cap end, 60mm.
Just though I mention it to save someone postage.
(Don't ask me how I know!)
Mark K
2001 4/4 Indigo Blue.
olive64 Offline OP
I found this on the forum ...
http://www.talkmorgan.com/ubbthreads.php/topics/134705/1
It's seems to me that my roll-over vent valve is defective. (Without pipe in the pic).
Who knows the mark and the type of this part ? notworthy
Alpine regards
Mini Cooper S 2017
