8 members (sewin, JMcL, Burgundymog, IcePack, BLUE+4, +8Rich, John V6, TheRabbit), 269 guests, and 31 robots.
+8Rich 99
Luddite 54
Topics49,905
Posts838,100
Page 6 of 8 1 2 3 4 5 6 7 8
Externally sourced quality control is still cost driven, and if it's done per unit, it wouldn't take long to run over with a couple of Friday cars. And apart from basic mechanical & MOT-worthy checks, plus door closure, and wheel alignment, what else can they do? They won't be removing all the screws to check they're the same!
And if anything comes to light which needs factory intervention, (eg paintwork or spares) that will add significantly to the logistics. So doing this work outside the factory doesn't appear to make much sense, unless the Chinese cars leave from Bristol?
Where is the holding warehouse for completed cars? Can somebody remind me?
Originally Posted By NeilM
[quote=Aldermog][quote=NeilM] .. or perhaps Williams are seeking world domination and eventual take over of the MMC. ooo
The THREE things that MMC should consider then are :
1. Employ my Mrs as chief hoover operator - she simply would not allow dust, shavings and swarf to remain on the vehicles ;
2. Use ONLY stainless steel nuts and bolts etc. (rust on a new product unacceptsble). Would it add more thsn a tenner to build costs ?
3. Employ Jays and Aldermog as pre-despatch inspectors for non-technical areas. If they pass a car, the customer will be satisfied too.
I'm serious about all 3 !
Jeremy
Originally Posted By Mike Hughes
Morgans were cheap performance cars for enthusiasts.
Now they're expensive cars being exported to more discerning customers.
With higher price comes greater expectation.
Exactly....especially in China. Morgan is selling at a luxury price point. They have to deliver the quality associated with the price point.
Enter Williams...
So basically, what you are saying is that the factory have to get an external party to check the quality before it gets shipped to more discerning customers. So if you are chinese, you get a wel built car, the rest of us, just have to accept second best. Strange old world.
Or you buy a car from Willims...
Williams are not perfect...... My car had a full service and mot but on the drive back to plymouth had three very irritating problems that should have been picked up
Another of my gripes is using scruffy floorboards. Maybe they don't start off scruffy.
Apply a plastic barrier sheet, build car, hoover, then peel and the boards would be immaculate.
Hoovering the swarf would literally be a couple of minutes.
Jeremy
Please leave me out of it Jeremy........I've just told DaveW that I'm not fastidious!
As far as stainless is concerned, I've very few nuts and bolts that are corroded badly and that's on a 2009 car. Very few, if any, car or motorbike manufacturers use stainless fasteners, so why should Morgan? Well.....perhaps the door hinge screws!
Dave....Northampton.
Drive on the Wild Side
somestickwell who are you kidding, I've seen Nero gleaming on several occasions even after having just been driven at least 50 miles to an event, I think I'll put you in the secret polisher club with Neillm, it's about time your outed! laugh2
Adrian
Only downside with stainless nuts and bolts is they can loosen more easily than mild steel ones that rust together.
Old wives tale, especially if you use nylocs, you wont have a problem with stainless nuts and bolts.
Peter J Offline OP
Formerly known as Aldermog
Jays, when you polish Nero do you:
1. Lift the bottom edge of the hood to make sure you polish underneath even though no one will see it?
2. Polish the under side of the doors, even though no one can know?
3. Polish the narrow strip of the wings that is inside the bonnet opening, only visible when opening the bonnet?
If you admitt to any of that you are a "Secret Polisher"!!
