7 members (IcePack, BLUE+4, Ruut Bianchi, Paulxj, JMcL, Burgundymog, Image),
251
Topics49,905
Posts838,100
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
So the problem was a fuse that had blown. Removed from the car and checked with a meter it showed conductivity. In the fuse box with power applied it didn't. I had spare fuses, but because it appeared good, both visually and with a meter, I didn't swap it out. I am somewhat irritated with myself. But relieved it wasn't anything more expensive!
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Great news Peter  . Odd that it showed as good with a meter
Steve L.
1996 Plus 8 N22 MOG
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
So the problem was a fuse that had blown. Removed from the car and checked with a meter it showed conductivity. In the fuse box with power applied it didn't. I had spare fuses, but because it appeared good, both visually and with a meter, I didn't swap it out. I am somewhat irritated with myself. But relieved it wasn't anything more expensive! Don't beat yourself up Peter, it's all a learning curve and how on earth (pun intended) were you supposed to find that. Great work from Williams in finding it, not easy. Breathe easy and enjoy the bank holiday in your car.
Posts: 983 |
Good news Peter, and at least not massive
Philip.
Posts: 472 |
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Keith at BHM told me that because some fuses are marginal, they can develop hairline cracks, so test ok, but when heated up will fail, only to cool and start working. So probably a hairline crack that would pass a test current but not full voltage.
Keith at BHM told me that because some fuses are marginal, they can develop hairline cracks, so test ok, but when heated up will fail, only to cool and start working. So probably a hairline crack that would pass a test current but not full voltage. That makes sense. The moral of the story is that if the logic says fuse "X" has blown, just change it.
The thing is, lessons like that you always remember! We've all been there
Posts: 3,643 |
Fantastic news. We can all sleep soundly now.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
The moral of the story is that if the logic says fuse "X" has blown, just change it. Yes but how do you know which one. I was polishing the horn button the other day and somehow managed to blow the fuse (that also effected other items, such as the radio). One by one I pulled all the fuses to check them one after the other and naturally it was the second last fuse of the whole bank that had blown.
