Topics49,860
Posts837,486
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
Every 1000 miles for me. Sometimes an extra shot in winter driving. Nick
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Looking through the Devol website it makes me wonder why the factory didn't stick with Devolin bushes and hard chrome pins. As some grades of Devolin are effectively self lubricating it could also be that the 1000 mile greasing would be less critical....
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
Mine typically last 25 k miles. New car has Devol so I am hoping to get the same. But I grease at 1000 miles on bronze & if an oiler was fitted oil at 500.
The Devol I am not so sure so for now I over grease as the handbook states 10k
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
Don't use the oiler - it washes the grease out (slowly)... Grease mine around the 500 - 800 mile mark (except when on holiday). Going to need KPs/bushes in next 12 months.
Posts: 3,643 |
Every 500-600 miles. When the time comes to replace, I will change to hard chrome king pins.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Every 600 to 1000 miles. I have a pneumatic greasegun so job is easy. When doing the lower nipples I lever up the baseplate/damper blade plate and grease until I see it coming out there. That way I know enough is in and the plate is lubricated - a tip given by Phil at Allon Whites to me when picking up my first Mog. Rear springs also sprayed with chain lube at same interval. Also propshaft.
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Note to self: must get some more chain lube for the rear springs before the next trip.
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
What sort of chain lube, chaps?
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
An alternate to chain lube is spray copper grease for the leaf springs
Posts: 472 |
Hi Geir, my original kingpins and bronze bushes were finished at 14000 miles (when I bought the car). I could see that the one-shot-oiler had been used. I have change them for hard chrome king pins and Vesconite Hi-Lube bushes including seals at the bottom end (you'll have to push the bushing in about 2,5 mm to accommodate for the seal). I think the seals are the best to protect both bushings and kingpins from dirt and grit getting in between the moving parts. Otherwise many recommend some form of gaiter around the 'open end' which I think is good too.
Lycka till!
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
