4 members (+8Rich, John V6, Bunny, Mike D), 243 guests, and 23 robots.
+8Rich 94
John V6 50
Posts837,998
rockabilly john
#219252 28/08/14 06:05 PM
There's no dipstick, and the oil cap is welded on, so how can we check the oil level? I 'm leaking oil from near the head gasket.
dogmanjack #219253 28/08/14 06:12 PM
Is this on a Three Wheeler? If so, the cap should not be welded, and should unscrew, when the oil level can be checked hot, immediately after turning off the engine. There is a thread about how to do it.
dogmanjack #219258 28/08/14 06:32 PM
Do we need to use a spanner to unscrew the nut on top of the cap?
dogmanjack #219261 28/08/14 06:39 PM
Dogmanjack, can you get your M3W to a nearby Morgan or Harley-Davison dealer to get then to check for you? Much better idea than using a spanner.
Ian
dogmanjack #219264 28/08/14 06:47 PM
I should add that I'm stuck in a remote part of Wales where there is no access to such luxuries as spanners and electricity.
Also, I really meant to ask if most people had a nut on the oil cap as most diagrams suggest otherwise, but mine has.
dogmanjack #219267 28/08/14 06:53 PM
Only hand
dogmanjack #219270 28/08/14 07:07 PM
The earlier versions have a nut on the top of the cap which holds a short dipstick underneath. The cap itself does unscrew but is often on quite tight - try a gloved hand or a rag to get a decent grip on the (hot) cap. Also you need to check the oil level with the engine reasonably hot and within a few minutes of switching it off or you can get a false low reading.
Hope this helps.
dogmanjack #219294 28/08/14 09:40 PM
The Knurled cap is threaded - but can get tight ...as suggested try warm/hot with a cloth or glove on ..it should come off!!! slap
Neil
dogmanjack #219305 28/08/14 10:27 PM
Thanks very much.
