8 members (JohnHarris, Mats, Montegue, stumog, Gordon D, Image, John V6, TalkMorgan),
376
82
Topics49,848
Posts837,408
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Its a bit like the term "lowline" I've never understood that term apart from when it was used back in the 50, early 60s to differentiate between high cowl and low cowl models. "Lowline"? "Lowline"?That's made me happier. . . . I thought the pompous oaf at Mog 2009 had said "Lowlife" . . .when refering to my 4/4.
Bud 4/4 "Stanley"
Posts: 2,562 Likes: 89
Posts: 2,562 Likes: 89 |
Narrow Body cars are exactly that - the tub is actually narrower. Before Morgan moved to a common chassis there were actually two widths available depending on model... mainly down to the introduction of the +8... though there are a few narrow body +8's built very early on.
Lowline - high and low cowl models
Longdoor - there were models built after a certain date where the doors are longer.. the earlier cars were short door and could pose problems for the taller or larger driver.
What confuses things is that whilst most newer +4's had more grunt and were wide body the narrow body was felt to handle better (for whatever reason) however the 4/4's always ended up with less power. This was resolved with the limited production 4/4 75th Anniversary model which ran a 2000cc engine despite being a 4/4. Therefore +4 Grunt in a narrow body chassis... last seen in the very early +4's (think TR era).
There is more detail to read up on in the Morgan history but this is why the now fabled Narrow Body 2000cc cars (as in the 75th Anniversary Model) are much sort after.
I have to say that the two 4/4's I have both running Zetec E engines. One 73 running a Black-top Zetec E with 175bhp and an 85 running a Black-top Zetec E with 250bhp would embarass most.. and at sprints can be seen giving the mid level Caterhams and Elises a run for their money. They are both much more nimble than the Class B 3.9 +8 I had a go in.
The Morgan suspension seems to be much more at home on the track maybe than out on the bumpy poor surfaced roads... where-as on a track the issues around progression and suppleness are seemingly less of a problem and many racers going for harder springs and less damping.
One other note that is worth adding which nobody seems to think about is that Morgan generally use off the shelf gearboxes.... the clusters within them designed for heavy saloons or rev ranges that don't match the driving nature of the Morgan. Quite often all the adjustment is done on the final drive in the rear diff. We have seen on the 4/4 the availability of a 4.1:1 diff as an option.
By keeping the same engine and swapping the cogs in the gearbox you can find that a smaller engined 4/4 becomes a very potent weapon in comparison to the larger cars.. with less weight it can often be a little more cheaky round the bends.
Looking at the level of development of certainly the more powerfull 4/4 I have I reflect on it as getting to the point of bolting Formula 3 grade components to a piece of wet spaghetti with the aerodynamics of a brick.... even with the double wishbone set-up that is available... look what you are bolting it to!! The top end Class B and A cars which run a full cage use the full allowance of mounting points to effectively build a new chassis (as in the roll cage) then bolt the car (the more twisty part of the pairing) to it. Cages starting from the rear suspension mounts at the back all the way forward to brace the front cross-head.
The number of times I've mused over what I would do regards a whole new chassis, suspension and streamlined body.. all be it in the Morgan theme...........................................hhhhmmm
Posts: 3,643 |
Budster, I am sure you will have mentioned it elsewhere can you remind me what BHP Stanley comes in at. Thanks.
Budster, I am sure you will have mentioned it elsewhere can you remind me what BHP Stanley comes in at. Thanks. 81.5Kw = 110BHP But not to be underestimated
Bud 4/4 "Stanley"
Posts: 3,643 |
Budster, not at all, from Stanley's (good) reputation.
Posts: 7,363 |
Its a bit like the term "lowline" I've never understood that term apart from when it was used back in the 50, early 60s to differentiate between high cowl and low cowl models. "Lowline"? "Lowline"?That's made me happier. . . . I thought the pompous oaf at Mog 2009 had said "Lowlife" . . .when referring to my 4/4.
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 14,009 |
Sorry to disagree but the tubs are all the same width on later cars, for example the 75th Anniversary 4/4 with the 2 litre Duratec is effectively the Plus4 with 4/4 wheels, 185 section tyres and the narrower 4/4 wings.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
It is so............. Nice to know the 4/4 Anniversary is sought after!
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
Coming to the marque as a new boy, it seems rather to be like smoke and mirrors on the part of the factory................
Sorry to disagree but the tubs are all the same width on later cars, for example the 75th Anniversary 4/4 with the 2 litre Duratec is effectively the Plus4 with 4/4 wheels, 185 section tyres and the narrower 4/4 wings. Sorry - didn't have my model books at work... there are some 2000cc 4/4's running around with early narrow bodies on. Both my 4/4's certainly have narrower bodies that my sisters +4. I appreciate that all the newer cars have the same size tub. @ PaulJ - it's not exactly smoke and mirrors.. if you look at the widest +8 (the 4.6 wide arch) and the narrowness of the 4/4 1600 xflow it's a style and image thing as much as comfort and engineering necessity. If you want a muscular brute the +8 gives you this message without even starting the car.. however the narrow 4/4 gives a real vintage style goggles and leather hats. Looking at the odd-balls and specials in between which make the individuality and colour of the Morgan models over the years. Half the fun is seeking out what you think is the ideal combination - all have been tried and are out there somewhere. When you see the one you like - snap it up - the chances of finding another is very slim unless it's one of the newer more standardised models (think 4/4 and +4 sport).
