2 members (+8Rich, Pittsartist), 171 guests, and 59 robots.
+8Rich 76
Topics49,863
Posts837,544
Page 3 of 3 1 2 3
Read T Offline OP
Quick question - I'm have a friend who TIG welds make a new aluminum radiator to fit in the mog. Not the exact same dimensions as the original, but should cool much better. I'm going to have him weld on a bung for the coolant temperature sensor, but noticed that the front bung on the thermostat housing (occupied currently by a plug) is the same thread as the sensor. Could I just screw the sensor into the thermostat housing instead? The only difference I would expect is that it would be mounted prior to the thermostat so would probably show the car warming up sooner.
1960 Morgan +4 4 seater
1997 Nissan 240sx S14
2011 Nissan 370Z
2009 Triumph Street Triple
Seems to be the obvious place for it to me - it would show the temperature of the coolant circulating around the block, not in the radiator. I assume it is for a temp gauge, not an electric fan switch.
Fjemog
1993 Plus 8
Page 3 of 3 1 2 3
