2 members (MOGDave, 2949olivier), 297 guests, and 40 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
All. I've noticed that the previous owner of my +8 has cut open the rubber cap on the end of the steering rack and then resealed with another cap (glued on top). I wonder what he was doing and whether I should be worried... Any thoughts? Thx
The original may have perished. It's an odd thing to double up though, because the cap can be removed easily and is a good way to check the lubricant and insert a bit more grease. If it's not recoverable, order a couple of new ones, they secure these days with cable ties, and take no time to fit. You don't need to remove the wheels for this. If you put the rack on lock so the end protrudes, you'll see how much lubricant is in there.
