0 members (),
349
Topics49,915
Posts838,214
Posts: 3,643 |
Although I have had the motor for 3 years, I have been thinking about the recent issues that Aldermog and Gambalunga with there fuses, so am considering swapping to the fuses with LEDs that come on when a fuse blows. When I looked at the Primary fuse box, the one in the engine compartment, I noticed that although there are 8 positions, only 7 contained fuses. According the a 2005 wiring diagram the far right hand fuse should be a 30amp fuse for the Ignition Switch. Does anyone with a similar plus 4 have a fuse "missing" like me?
Posts: 542 Likes: 7
Posts: 542 Likes: 7 |
The Fuse card I have for my 2013 +4 lists
1-ignition switch 30A 2-starter relay 30A 3-fuel pump/ignition relay 30A 4-cooling fan relay 40A 5-air conditioning 30A 6-dash module 20A 7-engine 20A 8-main fuse box feed 20A
Posts: 3,643 |
Thanks SS, Is there a fuse in each of the slots? Mine has been missing a 30amp in the far right hand slot. .
Posts: 542 Likes: 7
Interestingly, (or confusingly) it has a 20A fuse in it, but the list of fuses that is stuck to the car just below the fuse box lists it as
1 N-C
Which I assume means not connected, and is at odds with the printed copy of the fuse layout I was given with the car!
Posts: 3,643 |
SS you are a star. I will go with not connected as I got no readings on the Multi meter. Thanks for taking the time to look for me.
