0 members (), 456 guests, and 42 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
Georgetoad, woolfie
Although I have had the motor for 3 years, I have been thinking about the recent issues that Aldermog and Gambalunga with there fuses, so am considering swapping to the fuses with LEDs that come on when a fuse blows.
When I looked at the Primary fuse box, the one in the engine compartment, I noticed that although there are 8 positions, only 7 contained fuses.
According the a 2005 wiring diagram the far right hand fuse should be a 30amp fuse for the Ignition Switch.
Does anyone with a similar plus 4 have a fuse "missing" like me?
Ian
The Fuse card I have for my 2013 +4 lists
1-ignition switch 30A
2-starter relay 30A
3-fuel pump/ignition relay 30A
4-cooling fan relay 40A
5-air conditioning 30A
6-dash module 20A
7-engine 20A
8-main fuse box feed 20A
Thanks SS, Is there a fuse in each of the slots?
Mine has been missing a 30amp in the far right hand slot.
Ian
Interestingly, (or confusingly) it has a 20A fuse in it, but the list of fuses that is stuck to the car just below the fuse box lists it as
1 N-C
Which I assume means not connected, and is at odds with the printed copy of the fuse layout I was given with the car!
SS you are a star. I will go with not connected as I got no readings on the Multi meter.
Thanks for taking the time to look for me.
Ian
