2 members (DavidR, Carbuilder),
353
Topics49,897
Posts838,017
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
If you could see the condition of the front one (which sheared) you might consider the same John  The mounting plates/brackets are already stainless - wonder if replaced by a previous owner, I doubt they were factory fit (but I could be wrong)...
Posts: 199 |
This topics is useful for me as i want working double exhaust for Ms Green Tea
Posts: 14,009 |
This topics is useful for me as i want working double exhaust for Ms Green Tea Double? How's that going to work?
Posts: 58 |
Hi
My silencer front U clamp is in a sorry state and needs replacement.
Likewise the clamp on the cat. The rear clamp on the silencer is not too bad but will be changed too.
What I need are the dimensions! I will assume the silencer clamps are the same but is the cat clamp too?
I will order stainless but need the sizes if anyone can help? OP if he's reading this.
Seems insane that Morgan do not used quality clamps for a few quid more...
2000 4/4 Reg - W459CEV - Sold 2012 4/4 Sport Reg - PBO17 - Sold Looking for a Plus 4 Supersports
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
I can't check at the moment but 54mm has a familiar ring. U clamps are usually stamped with the size.
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
Last year I had to replace 2u-clamps on the front mounts of the main silencers. Bought plain ones from Halfords as a quick/temp finish. Smeared some copper grease on them it resists heat up to a point. They are still good after 7k miles. Further forward on the system the flange joints are badly corroded so will soon need replacement. Finding replacements will be a soon to ge done search. The system itself is stainless(manifolds are cast originals and in good nick) so mild steel fittings seems a bad bit of penny pinching. So far the flanges I have seen may not suit as they need to slip over the cat/downpipe flared ends before bolting up. It looks like they are fitted before the pipe ends are flared/forned. I will search for split flanges
