Morgan Aero 8
4 members (B3MOG, MJF, Bunny, Massi_torino), 188 guests, and 91 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,628
Moggo
#223681 21/09/14 07:08 PM
346VAB Offline OP
Baffled by this oil leak which albeit minimal and appears to be coming from the RMS, have googled lots and read plenty of BMW forum threads but this does not appear to be a common failure at all!? My car is is a 2003 and only covered 12k miles, I welcome your expert knowledge.
Kind regards
Chris
Aero 8 Series 1
Audi TT Mk1
Please could you advise what is "RMS"?
Philip
1985 Plus 8 four seater
Malone F1000 - track car
Rear main seal?
Martin (Deano)
Chris,
I had an oil leak found on service in January this year on my S1 Aero, with Brian Miller. Turned out to be a fairly common leak from the seals at the remote oil filter. They perish over time. You might just check yours. They are straightforward to replace.
Dave
346VAB Offline OP
If only, no its not that I had that problem 2 years ago but fixed for the price of a new oil filter from BMW.
Kind regards
Chris
Aero 8 Series 1
Audi TT Mk1
11 year old engine hardly used?
Chances are the seal has dried out maybe even cracked.
I'd fit a new one then monitor for further leakage
Mark - No Longer driving
Sir S1'a'lot
Sir S1'a'lot
Mine is 4000 miles and 2002....no such leaks
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Chris, Dave mentioned the seals at the oil filter (and I take it he meant O rings on oil pipes from the engine block). These same pipes also have seals at the other end where they go into the block. Mine had perished causing quite a bad oil leak that wasn't visible to. the eye from any angle. The O rings are penny cheap but an absolute pig to replace😡😡😡. I seem to remember having to make up a special tool to undo the bolt on the bracket holding the pipe into the block.
Cheers
Philip
Phillip
Not sure of work done as I had the car transported to Millers and did not get to see the leak first hand. Itemised bill describes the following "remove remote oil filter housing to engine hoses and replace leaking seals".
Dave
Dave, almost certainly it was the O rings on the hoses to and from the filter since only other item that could leak there is oil filter housing.
Cheers
Philip
