1 members (Alan Patterson),
178
49
Topics49,846
Posts837,382
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Can I tempt you a bit? I have put together a composite chart from one published by Morgan and chart published on Facebook for the Omex Throttle Body kit and for the TB kit plus Omex cams. As you can see it develops nearly 200 hp with the cams and actually more than the SS at the same revs. The SS with variable cams wins out at low to mid range however. The two cars were also fitted with Williams sports exhaust system I believe.  [/quote]
Posts: 517 |
The graphs are interesting Peter and confirm what I have always felt that there is a dip in torque at around 3000 revs. This is especially noticeable in 5th. Stop tempting me with those TB's Titus
Titus
2007 +4 4 seater 2017 Mini Cooper 2007 VW Camper 1996 Honda TRX300 2012 Husqvarna 216
The interesting thing there is that 3,000 rpm is the engine speed used for the "fast idle" in the MOT or equivalent emission tests.
I wonder if the map is "adjusted" to ensure the engine passes the test.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
That's almost certainly why...........
Cynical? Me?
Posts: 2,361 |
The remap can be done in a single day and is retailed at £399.
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 564 Likes: 8
Posts: 564 Likes: 8 |
Have you had a go at a GDI yet?
Andrew 'Alice' 2013 Duratec Plus 4. Pearl Blue
Posts: 881 |
I was talking to a fellow TM about Williams, could you send your ECG to them to get remapped or is there more work on the engine to be done
Very much in the dog house, could be up for rehoming
Posts: 2,361 |
I'm the 1 of 2 techs at Williams  You can send us your Ecu
Posts: 1,653 |
Can it be done on a new 4/4 Sigma also by post?
Posts: 2,361 |
Can it be done on a new 4/4 Sigma also by post? I'm not 100% sure but we can do the Sigma
